[OpenLayers-Trac] [OpenLayers] #3519: build.py -c closure: Show
file name and line number of errors and warnings.
trac-20090302 at openlayers.org
Sun Sep 25 07:00:53 EDT 2011
#3519: build.py -c closure: Show file name and line number of errors and warnings.
Reporter: jorix | Owner:
Type: feature | Status: new
Priority: minor | Milestone: 2.12 Release
Component: general | Version: 2.11
Keywords: build closure | State:
When errors or warnings from compilation is more comfortable to see
directly where they are produced. Currently must guess the location of the
errors using {{{OpenLayers.js}}} obtained by {{{build.py -c none}}}.
To obtain this feature is necessary pass to the compiler a list of
filenames instead of the merged file.
The implementation proposes to use [http://code.google.com/p/closure-
library/source/browse/trunk/closure/bin/build/jscompiler.py jscompiler.py]
used in the Closure Library. Changes are proposed in {{{mergejs.py}}} so
can return a merged file or a list of files, but has remained the same
code for the selection and determine order of source files. There are also
changes in {{{build.py}}}
Ticket URL: <http://trac.openlayers.org/ticket/3519>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
