[OpenLayers-Trac] Re: [OpenLayers] #2862: Panel: decouple the
appearance of the icons to the Controls
trac-20090302 at openlayers.org
Sun Sep 25 17:38:46 EDT 2011
#2862: Panel: decouple the appearance of the icons to the Controls
Reporter: jorix | Owner: jorix
Type: feature | Status: new
Priority: minor | Milestone: 2.12 Release
Component: Control.Panel | Version: 2.10
Keywords: | State: Review
Changes (by jorix):
* state: Needs Discussion => Review
Comment:
Replying to [comment:3 erilem]:
> With the current design panels aren't meant to include UI controls,
panels create buttons/toggles for non-UI controls. So the current rule is
don't use panels for composing UI controls. I don't think we should
attempt to change that design, at least not for 2.11. I'm therefore
bumping this ticket to 2.12, please change it back to 2.11 and provide
explanations if my comments don't make sense.
The proposal of this improvement is not breaking the previous behavior,
and it gives more flexibility in the design of the panels. It also gives
the possibility of extending the use of {{{panelIcon}}} for new properties
of the icons (I think for example: text icons).
After updated with the trunk and add more test I put in revision for 2.12
Ticket URL: <http://trac.openlayers.org/ticket/2862#comment:9>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
