[OpenLayers-Trac] [OpenLayers] #3523: ZoomBox - The box remains on the map.
OpenLayers trac-20090302 at openlayers.org
Tue Sep 27 01:27:28 EDT 2011
 Reporter:  justin           |       Owner:
     Type:  feature          |      Status:  new
 Priority:  minor            |   Milestone:  2.12 Release
Component:  Control.ZoomBox  |     Version:  2.11
 Keywords:  ZoomBox          |       State:
 - Hold down shift and drag
 - BEFORE you release your left click after dragging, '''right click'''
 Problem: The ZoomBox remains on the map. You can add multiple ZoomBox if
 you repeat the steps above.
 Note: Same problem even with using the ZoomBox Control as tool.
 Check it out on
 [http://dev.openlayers.org/releases/OpenLayers-2.11/examples/navtoolbar-
 alwaysZoom.html]
Ticket URL: <http://trac.openlayers.org/ticket/3523>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
