[OpenLayers-Trac] Re: [OpenLayers] #3529: CanvasRender:
ExternalGraphic + Label end up in wrong order
trac-20090302 at openlayers.org
Wed Sep 28 06:35:21 EDT 2011
#3529: CanvasRender: ExternalGraphic + Label end up in wrong order
Reporter: arsgeografica | Owner:
Type: bug | Status: new
Priority: minor | Milestone: 2.12 Release
Component: general | Version: 2.11
Keywords: | State: Needs More Work
Changes (by marcjansen):
* state: => Needs More Work
Comment:
Hi arsgeografica,
I can reproduce your described issue and the patch seems to be fixing it.
But the patch also changes the labeling behaviour of e.g. polygons. If a
user specifies an externalGraphic and label for a polygon feature, with
the old behaviour the label gets drawn and the externalGraphic is being
ignored. With your patch applied, the label would also be ignored for a
polygon feature.
You can easily test that when you change /examples/vector-features-with-
text.html?renderer=Canvas
to have an externalGraphic configured in the stylemap for the vector layer
(~ line 43).
If possible please update the patch to
* not fail the test test_drawFeature in tests/Renderer/Canvas.html
* include a test for the new drawing order (I cannot tell how hard that
is)
* keep the old behaviour of also labeling e.g. polygons even if there is
an externalGraphic
* have a maximum length of 80 characters per line
I will have another look then.
Ticket URL: <http://trac.openlayers.org/ticket/3529#comment:1>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
