[OpenLayers-Trac] [OpenLayers] #3622: ModifyFeature fails if
styleMap has max/minScaleDenominator
trac-20090302 at openlayers.org
Thu Feb 16 07:47:29 EST 2012
#3622: ModifyFeature fails if styleMap has max/minScaleDenominator
Reporter: josnic | Owner: tschaub
Type: feature | Status: new
Priority: minor | Milestone: 2.12 Release
Component: Control.ModifyFeature | Version: 2.11
Keywords: | State:
OpenLayers.Control.ModifyFeature fails to initialize if the layer has a
styleMap with max/minScaleDenominator values set.
The cause seems to be that ModifyFeature needs to create another style in
it's initialize method. This is done by a the call
this.layer.styleMap.createSymbolizer(null, options.vertexRenderIntent).
This creates a new feature without a layer attached to it.
This will in turn call [Style].createSymbolizer(), this will check rules
and eventually call [Rule].evaluate method. The evaluate method will check
for max/minScaleDenominator and tries to use the layer to the feature,
which is null.
My workaround has been to create another ModifyFeature class and create a
feature with a layer before calling createSymbolizer() method.
Example to recreate bug:
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
"http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1">
<title>ModifyFeature and Style Rules min/maxScaleDenominator</title>
<script type="text/javascript"
src="http://openlayers.org/api/OpenLayers.js"></script>
<script type="text/javascript">
function demo() {
var ruleLow = new OpenLayers.Rule({
"minScaleDenominator": 40000,
symbolizer :
OpenLayers.Util.applyDefaults({},OpenLayers.Feature.Vector.style["default"])});
var ruleHigh = new OpenLayers.Rule({
"maxScaleDenominator": 40000,
symbolizer :
OpenLayers.Util.applyDefaults({},OpenLayers.Feature.Vector.style["selected"])});
var style = new OpenLayers.Style(null, {
rules:[ruleLow,ruleHigh]
var map = new OpenLayers.Map("map");
var vector = new OpenLayers.Layer.Vector("Vector layer", {
styleMap: new OpenLayers.StyleMap(style)
map.addLayer(vector);
// Get exception here !
var modifyControl = new
OpenLayers.Control.ModifyFeature(vector);
</script>
</head>
<body onload="demo()">
<div id="map"></div>
</body>
</html>
Ticket URL: <http://trac.openlayers.org/ticket/3622>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
