[OpenLayers-Trac] [OpenLayers] #3601: SelectFeature with LineString
does not work
trac-20090302 at openlayers.org
Fri Jan 6 04:48:17 EST 2012
#3601: SelectFeature with LineString does not work
Reporter: stafy | Owner: tschaub
Type: bug | Status: new
Priority: blocker | Milestone: 2.12 Release
Component: Control.SelectFeature | Version: 2.11
Keywords: | State:
Following problem: My base layer is a OpenLayers.Layer.OSM.Osmarender
layer. I draw a line with OpenLayers.Geometry.LineString in a second
vector layer. With the Openlayer SelectFeature I want to select this line.
But this is only possible at the startpoint and the endpoint.
Here is my html code.
Click on the blue thick line selects the line only at startpoint and
endpoint.
<html>
<head>
<title>OpenLayers Example</title>
<script src="http://www.openlayers.org/api/OpenLayers.js"></script>
<script
type="text/javascript"src="http://www.openstreetmap.org/openlayers/OpenStreetMap.js"></script>
</head>
<body>
<div style="width:100%; height:100%" id="map"></div>
<script defer="defer" type="text/javascript">
//create map
var options = {
projection: new OpenLayers.Projection("EPSG:900913"),
displayProjection: 'EPSG:4326',
units: "m",
maxResolution: 156543.0339,
maxExtent: new OpenLayers.Bounds(-20037508.34, -20037508.34,
20037508.34, 20037508.34),
controls: [new OpenLayers.Control.PanZoom(),
new OpenLayers.Control.Navigation(),
new OpenLayers.Control.MousePosition({"numDigits":
8,
displayProjection: new
OpenLayers.Projection("EPSG:4326"),emptyString:"outside the map"}),
map = new OpenLayers.Map('map', options);
// create OSM layer
osm_osma = new OpenLayers.Layer.OSM.Osmarender('OpenStreetMap Osmarender',
{minZoomLevel: 0,
maxZoomLevel: 100,
isBaseLayer: true
map.addLayers([osm_osma]);
var lonlat=transformLonLat("8.3191929972096", "49.015806343698", false);
map.setCenter(lonlat, 17);
//create vector-layer
// Layerstyle
var vlayer_style = OpenLayers.Util.extend({},
OpenLayers.Feature.Vector.style['default']);
vlayer_style.fillOpacity = 0.6;
vlayer_style.fillColor = "green";
vlayer_style.strokeWidth = 6;
vlayer_style.strokeColor = "blue";
vlayer_style.strokeOpacity = 1;
var select_style = OpenLayers.Util.extend({}, vlayer_style);
select_style.fillOpacity = 0.6;
select_style.strokeWidth = 10;
select_style.strokeColor = "black";
select_style.fillColor = "black";
var vStyleMap = new OpenLayers.StyleMap( {
"default" :vlayer_style,
"select" :select_style
var vlayer = new OpenLayers.Layer.Vector("vlayer", {styleMap: vStyleMap});
map.addLayer(vlayer);
//create SelectFeatures
var selectControl=new
OpenLayers.Control.SelectFeature(vlayer,{displayClass: "selectButton",
title: 'Select Ways',
onSelect:selected,
onUnselect:unselected,toggle:false,clickout:true,multiple:false,
hover:false,toggleKey:"ctrlKey", multipleKey:"shiftKey",geometryTypes:
["OpenLayers.Geometry.LineString"],
callbacks: {
'over': feature_hover,
'out': feature_hover_out
map.addControl(selectControl);
selectControl.activate();
//Draw Linestring
var waypoint_lon="8.3096336042805";
var waypoint_lat="49.016608500028";
var lonlat=transformLonLat(waypoint_lon, waypoint_lat, false);
var point=new OpenLayers.Geometry.Point(lonlat.lon, lonlat.lat);
var arrPoint =[];
arrPoint.push(point);
waypoint_lon="8.3274863874837";
waypoint_lat="49.016249642214";
var line = new OpenLayers.Geometry.LineString(arrPoint);
var lineF = new OpenLayers.Feature.Vector(line,null);
vlayer.addFeatures([lineF]);
//Functions
function transformLonLat(lon, lat, anzeige) {
var lonlat1 = null;
if (anzeige==true)
lonlat1=new OpenLayers.LonLat(lon, lat).transform(
new OpenLayers.Projection("EPSG:900913"), // Spherical
Mercator Projection
new OpenLayers.Projection("EPSG:4326") // WGS 1984,
else
new OpenLayers.Projection("EPSG:4326"), // WGS 1984,
new OpenLayers.Projection("EPSG:900913") // Spherical Mercator
Projection
return lonlat1;
function feature_hover( feature ){
feature.layer.div.style.cursor = "crosshair";
function feature_hover_out( feature ){
feature.layer.div.style.cursor = "";
function selected (obj) {
alert("select");
function unselected (obj) {
alert("deselect");
</script>
</body>
</html>
Ticket URL: <http://trac.openlayers.org/ticket/3601>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
