[OpenLayers-Trac] [OpenLayers] #3604: oRequest is not defined
posting XML
trac-20090302 at openlayers.org
Tue Jan 10 07:34:17 EST 2012
#3604: oRequest is not defined posting XML
Reporter: kikearake | Owner:
Type: bug | Status: new
Priority: minor | Milestone: 2.12 Release
Component: general | Version: 2.11
Keywords: oRequest is not defined | State:
When i use the OpenLayers.Request.POST with xml document, i recieve
"oRequest is not definded".
Browsing the code i see:
cXMLHttpRequest.prototype.send = function(vData) {
// Add method sniffer
if (cXMLHttpRequest.onsend)
cXMLHttpRequest.onsend.apply(this, arguments);
if (!arguments.length)
vData = null;
// BUGFIX: Safari - fails sending documents created/modified
dynamically, so an explicit serialization required
// BUGFIX: IE - rewrites any custom mime-type to "text/xml" in
case an XMLNode is sent
// BUGFIX: Gecko - fails sending Element (this is up to the
implementation either to standard)
if (vData && vData.nodeType) {
vData = window.XMLSerializer ? new
window.XMLSerializer().serializeToString(vData) : vData.xml;
if (!oRequest._headers["Content-Type"])
oRequest._object.setRequestHeader("Content-Type",
"application/xml");
this._data = vData;
// Add to queue
if (this._async)
fQueue_add(this);
else*/
fXMLHttpRequest_send(this);
in XMLHttpRequest.js
If i change "oRequest" with "this" in this lines
"application/xml");
it works(no error).
It's a bug? or i'm missing something?
Ticket URL: <http://trac.openlayers.org/ticket/3604>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
