[OpenLayers-Trac] Re: [OpenLayers] #3228: Double tap on Android
select the map
trac-20090302 at openlayers.org
Thu Jan 26 08:15:45 EST 2012
#3228: Double tap on Android select the map
Reporter: sbrunner | Owner: tschaub
Type: feature | Status: new
Priority: minor | Milestone: 2.12 Release
Component: Events | Version: 2.10
Keywords: mobile | State: Review
Comment(by gregers):
I think the patch is a bit scary. First of all, we don't know that the
device has touch capabilities just because the browser exposes touch
events. It seems to work today, but we don't know what browser vendors do
in the future. Chrome exposed the touch events when they first implemented
them (http://code.google.com/p/chromium/issues/detail?id=36415), and that
resulted in our users with chrome could not use the mouse (we had a
similar touch event check in our own code). Luckily Chrome decided to
disable touch events by default. I asked if w3c could add a note that
touch events should be hidden for devices without touch capabilities in
touch events spec, but they didn't add it. The risk of a new browser
exposing touch events is pretty low, but the consequence of this happening
is really bad (none of their users can use the mouse). With todays
browsers fast release cycles, the problem can arise quickly mid OpenLayers
releases.
Also, what about devices with both touch and mouse capabilities? There are
several on the market already
(http://www.asus.com/Eee/Eee_Pad/Eee_Pad_Transformer_TF101/). Do we want
to force these users to only use the touch capabilities?
Sorry that I don't have a better solution at hand, but I don't have an
Android test device :( How about an option to not bind the mouse events?
That would make it easy to turn off if it becomes a problem in the future?
Ticket URL: <http://trac.openlayers.org/ticket/3228#comment:10>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
