[OpenLayers-Trac] Re: [OpenLayers] #3634: WMSGetFeatureInfo does
work across the 180 line.
trac-20090302 at openlayers.org
Thu Mar 8 02:46:02 EST 2012
#3634: WMSGetFeatureInfo does work across the 180 line.
Reporter: scaddenp | Owner:
Type: bug | Status: new
Priority: major | Milestone: 2.12 Release
Component: general | Version: 2.11
Keywords: | State: Awaiting User Feedback
Changes (by ahocevar):
* state: => Awaiting User Feedback
Comment:
The bbox that OpenLayers uses for the GetFeatureInfo request should be the
same as for the GetMap request. In the example above, the llbbox is
150.30,-50.17,190.69,-30.78. Now two interesting questions: what is your
layer's maxExtent in the GetCapabilities response? And does the url below
return a feature info?
http://maps.gns.cri.nz/geoserver/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&LAYERS=gns%3APETROLEUM.NZ_2D_SEIS_LINES&QUERY_LAYERS=gns%3APETROLEUM.NZ_2D_SEIS_LINES&STYLES=&BBOX=16731556.455300998%2C-6475305.631310003%2C1189768.3702969998%2C-3603719.353092&FEATURE_COUNT=1&HEIGHT=587&WIDTH=919&FORMAT=image%2Fpng&INFO_FORMAT=application%2Fvnd.ogc.gml&SRS=EPSG%3A900913&X=754&Y=363
Note that this is the same url as your original one, but with the right
edge at 10.69 instead of 190.69.
Ticket URL: <http://trac.openlayers.org/ticket/3634#comment:1>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
