[OpenLayers-Trac] Re: [OpenLayers] #3634: WMSGetFeatureInfo does work across the 180 line.
OpenLayers trac-20090302 at openlayers.org
Thu Mar 8 15:47:13 EST 2012
 Reporter:  scaddenp  |       Owner:
     Type:  bug       |      Status:  new
 Priority:  major     |   Milestone:  2.13 Release
Component:  general   |     Version:  2.11
 Keywords:            |       State:
Comment(by scaddenp):
 Okay, thanks very much for that clarification. I have posted on geoserver
 list. (GEOS-4991)
 I'm prepared to consider a hack meantime though. It should possible to
 tell whether the position is left or right of 180, so surely only one
 getfeatureInfo is required?
 The trick though is splitting the mapextent to create a properly formed
 URL. Given the URL above generated an error, what would a correct URL look
 like? If I know that, I can probably hack away from there.
Ticket URL: <http://trac.openlayers.org/ticket/3634#comment:3>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
