[OpenLayers-Trac] Re: [OpenLayers] #2965: Add halos to vector labels
trac-20090302 at openlayers.org
Sat Mar 17 06:37:18 EDT 2012
Reporter: rdewit | Owner:
Type: feature | Status: new
Priority: minor | Milestone: 2.13 Release
Component: Renderer | Version: 2.10
Keywords: | State: Needs Discussion
Comment(by DonaldKerr):
Replying to [comment:11 rdewit]:
> Don't expect to get it in 2.12 though. I'm still waiting for some IE
wizard to step up to fix the font problem.
Buggy IE VML: Styles on both shape and textpath don't behave well at all
when using javascript.
'''A solution to the font problem''': The only way I have found this to
work was specifying it in textpath.style.font. This doesn't behave as
documented ([http://msdn.microsoft.com/en-
us/library/bb264023(v=vs.85).aspx]) as not all values can be changed with
script. This specifies the order as "font-style, font-variant, font-
weight, font-size, line-height, and font-family." - Don't believe it as
they don't all work and it's quite quirky.
Change the line where you set the fontSize (default 10 or whatever's
specified in the style) from:
textpath.style.fontSize = style.fontSize || 10;
to:
textpath.style.font = "10 "+style.fontFamily;
if (style.fontSize) {
textpath.style.fontSize = style.fontSize;
The default of 10 is applied whether or not the fontFamily is passed from
the style. If the fontFamily is specified then that too is applied.
Ticket URL: <http://trac.openlayers.org/ticket/2965#comment:24>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
