[OpenLayers-Trac] [OpenLayers] #3654: The CQL format does not
support wildcard in value (for LIKE operator).
trac-20090302 at openlayers.org
Tue May 8 19:04:05 EDT 2012
#3654: The CQL format does not support wildcard in value (for LIKE operator).
Reporter: scaddenp | Owner: tschaub
Type: bug | Status: new
Priority: critical | Milestone: 2.13 Release
Component: Format.CQL | Version: 2.11
Keywords: CQL Parsing | State:
An expression like:
TRANS_NAME LIKE 'OTS%' fails because % is not a valid character.
It should be noted that this format reader supports only a limited syntax
compared to what server CQL expressions are supported. (eg
TRANS_NAME NOT LIKE 'OTS%' or
TRANS_NAME !NOT LIKE 'OTS%' are valid on the server but not to CQL.js
which requires NOT TRANS_NAME LIKE 'OTS%'
Ticket URL: <http://trac.openlayers.org/ticket/3654>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
