[OpenLayers-Trac] [OpenLayers] #3655: ArgParser/Permalink doing
doule requests?
trac-20090302 at openlayers.org
Sat May 12 13:52:52 EDT 2012
#3655: ArgParser/Permalink doing doule requests?
Reporter: febus982 | Owner: crschmidt
Type: bug | Status: new
Priority: major | Milestone:
Component: Control.Permalink | Version: 2.11
Keywords: | State:
I have a map with some WMS layers, and found some bugs:
1 - If you use ArgParser the map request to WMS server the default layers,
and after this the layer referenced on the URL. So the client is making
double requests.
I understand that behaviors are attached after map creation, but this
feature should be moved in the creation map phase and not as a map
behavior to bypass this bug.
2 - I tried disabling argparser and doing parsing on server side, but it
seems that Permalink is doing argument parsing even with ArgParser
disabled.
Ticket URL: <http://trac.openlayers.org/ticket/3655>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
