[OpenLayers-Trac] [OpenLayers] #3661:
OpenLayers.Format.EsriGeoJSON: a format to
convert ArcGIS Server REST GeoJSON output to GeoJSON being used by
trac-20090302 at openlayers.org
Mon May 21 16:14:57 EDT 2012
#3661: OpenLayers.Format.EsriGeoJSON: a format to convert ArcGIS Server REST
GeoJSON output to GeoJSON being used by OpenLayers
Reporter: liuxd8510 | Owner: tschaub
Type: feature | Status: new
Priority: minor | Milestone:
Component: Format | Version: 2.11
Keywords: ArcGIS Server; ESRI; REST; GeoJSON; | State:
Our OpenLayers application has a demand of directly and dynamically
loading data from the vector output (GeoJSON) of a bunch of ArcGIS Server
REST services. OpenLayers doesn't have a native support in doing so.
Referring to an example [http://mapbutcher.com/blog/2008/10/07/arcgis-
server-rest-api-openlayers-and-some-potatoes/] (it uses Polygon as
example) as the starting point, we extended the support to all other
geometry types
(Point/Multipoint/LineString/MultiLineString/Polygon/MultiPolygon) and
packed them into a new Format (inherits from GeoJSON format).
'''how to use:'''
var new_geojson_layer = new OpenLayers.Layer.Vector("Esri_URL_GeoJSON", {
strategies: [new OpenLayers.Strategy.Fixed()],
protocol: new OpenLayers.Protocol.Script({ //to get around cross-
domain if this issue exists
url: arcgis_rest_query_url, //ArcGIS Server REST GeoJSON
output url
format: new OpenLayers.Format.EsriGeoJSON(),
parseFeatures: function(data) {
return this.format.read(data);
'''or:'''
var new_protocol = new OpenLayers.Protocol.Script({ //using this protocal
to request output from a given output_url
callback: function(response) { //data is returned
var esri_geojson_format = new
OpenLayers.Format.EsriGeoJSON();
var new_features = esri_geojson_format.read(response);
//parse ESRI_GeoJSON to OpenLayers Features
if(new_features) {
new_geojson_layer.addFeatures(new_geojson_layer);
'''Note:'''
We are not sure whether it's necessary to output OpenLayers feature to
ESRI GeoJSON, so for now, the wirte() is same as the one in
OpenLayers.Format.GeoJSON.
Hope this is something helpful to other OL users.
Ticket URL: <http://trac.openlayers.org/ticket/3661>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
