[OpenLayers-Users] TileCache and KaMaps
Tim Schaub
noreply at geocartic.com
Tue Dec 5 18:38:29 EST 2006
> http://sigma.openplans.org/dev/test-meta.html
If this is really meta tiles, I'd be interested to see how you're getting
transparency. Has anybody else confirmed that PIL gets rid of transparency
when doing the image crop?
Tim
> The second uses metaTile for the tiger layers, the first
> doesn't, everything else is the same. Overlaid on the
> bluemarble layer, however, everything in tiger is shifted
> south, the outlines don't match. Not sure if there was
> something I configured wrong, but all I did was add metaTile=true.
> When testing on its own it seemed to be working, definitely
> less 'United States' labels on my page. So the root concept
> seems to be working, which is great news.
> I'll also note that right now it seems to be having more
> blank images.
> It's not all pre-cached. I've actually consistently had
> problems with areas that aren't pre-cached, they tend to not
> wait until the backend has returned, instead just return the
> broken images. It would be great if I could get it so
> there's never the broken images, some just take a lot longer to load.
> best regards,
> Chris
> It also doesn't hook directly into mapscript (and
> > there aren't plans to, though it could in the future) to use added
> > capabilities of MapServer like ka-map does. It also (due to lack of
> > support in the Python Imaging library) doesn't support chopping up
> > transparent tiles and maintaining transparency: this means that you
> > can't metaTile transparent images.
> > TileCache is young. It hasn't been tested on dozens or hundreds of
> > installs like ka-Map has been.
> > TileCache is written in Python. It doesn't require
> mapscript. It can
> > be run on a service which is far from your original service
> (via WMS
> > cascading). The code is clean. It runs under CGI or mod_python.
> > TileCache supports multiple request formats. WorldWind, WMS-C, TMS.
> > TileCache supports multiple data backends: mapserver (via
> mapfiles),
> > WMS cascading, mapnik, and is easy to extend to anything
> else -- for
> > example, one of the next additions I'm going to look into
> is an ArcXML
> > layer. This means that if you have a custom data source,
> it's probably
> > easy for you to wrap it in TileCache.
> > TileCache is, for the most part, a replacement for ka-Map. However,
> > it's an immature project, and may not fit all the needs
> that everyone has.
> > The metaTiling support, in particular, is not extremely
> well tested,
> > and that is the primary benefit that ka-Map offers.
> However, based on
> > empirical testing, I feel that it's likely that for many cases,
> > TileCache will be much faster than ka-Map, and I think that
> it's more
> > likely to be maintained and extended in the future than ka-Map's
> > rendering tool.
> > Personally, I'm working to migrate all my ka-Map based instances to
> > TileCache. If TileCache doesn't do it, then my steps will
> be to make
> > TileCache do it, rather than setting up ka-Map. However, I have not
> > yet migrated any projects which require metaTiling to TileCache, so
> > I'm not yet convinced of its stability at that particular task.
> > Anything which doesn't require metaTile support, I would absolutely
> > recommend
> > TileCache: I'm not to the same point with anything which requires
> > metaTile support yet.
> > Regards,
> Chris Holmes
> The Open Planning Project
> http://topp.openplans.org
