[OpenLayers-Users] Popup.setSize() - any reason why it should break
in 2.2?
Nick Whitelegg
nick at hogweed.org
Tue Dec 19 19:08:38 EST 2006
I've just converted my custom "GeoRSS2" layer (a layer which can handle
retrieval of GeoRSS features within a bounding box) from OpenLayers 2.1 to
2.2. However one line breaks - I can no longer set the size of a popup within
the markerClick function - I get the error "quadrant has no properties".
My markerClick function is modified from the original GeoRSS.js function to
handle deleting the marker if a user is in a certain mode, and is as below.
Full code (if needed) is at http://www.free-map.org.uk/test/GeoRSS2.js.
Is this an API change?
Thanks,
Nick
markerClick: function(evt) {
if(this.layer.deleteTestFunction && this.layer.deleteFunction &&
this.layer.deleteTestFunction()) {
this.layer.deleteFunction(this.id);
this.layer.removeMarker(this.marker);
this.destroy();
} else {
sameMarkerClicked = (this == this.layer.selectedFeature);
this.layer.selectedFeature = (!sameMarkerClicked) ? this : null;
for(var i=0; i < this.layer.map.popups.length; i++) {
this.layer.map.removePopup(this.layer.map.popups[i]);
if (!sameMarkerClicked) {
var popup = this.createPopup();
// This breaks in 2.2
//popup.setSize(this.layer.popupSize);
popup.setBackgroundColor(this.layer.popupColour);
OpenLayers.Event.observe(popup.div, "click",
function() {
}.bindAsEventListener(this));
this.layer.map.addPopup(popup);
OpenLayers.Event.stop(evt);
