[OpenLayers-Users] OpenLayers 2.2, Firefox 2.0,MapServer WMS
Justin Fail
justin.fail at gmail.com
Wed Nov 15 19:15:04 EST 2006
Yes, I'd been messing around with different options for the layers and map,
so there were some remnants left over.
I made your changes to the Layer parameters and options and what do you know
- it all appears fine in FF2.0 again.
Even using port 80.
Thanks.
Now to figure out how to over-ride these event handlers....
On 16/11/06, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> On Wed, Nov 15, 2006 at 02:47:08PM -0800, Justin Fail wrote:
> > Hi All,
> > I've recently starting testing with OpenLayers (ie. yesterday) and my
> test
> > sites worked fine with version 2.1.
> > I transferred to version 2.2 today and now my app does not work in
> Firefox
> > 2.0. It works fine in IE 6.
> > Anything that I'm doing wrong here, or could be doing better?
> There's a couple things I'd mention.
> > var wms = new OpenLayers.Layer.WMS.Untiled( "UCL WMS",
> > "http://localhost/cgi-bin/mapserv_tracker.exe?service=WMS", {layers:
> 'Coastline',format:'gif',buffer:1,maxExtent:maxBounds,maxResolution:'auto'}
> You're adding 'buffer', maxExtent, etc. into the params of the layer
> instead of the options. This should be:
> 'Coastline',format:'gif'},{buffer:1,maxExtent:maxBounds,maxResolution:'auto'}
> Additionally, for untiled, buffer doesn't make any difference.
> However, when I take your code and look at it in FF 1.5 and FF2.0 it
> seems to work (other than not being able to generate an image). OL 2.2
> does introduce some rather strict checking of the tile URL to ensure it
> matches the tile that was asked for. If you are using a port 80 in your
> URL, this might be your problem: http://localhost:80/ won't work,
> because Firefox strips the :80 from the URL of the img.src after loading
> the image. (Improving this behavior is on the chopping block for 2.3.)
> Can you reproduce the failure with any of the examples in the
> distribution?
> If you need to get up and running, you can use
> http://openlayers.org/api/2.1/OpenLayers.js while we work to resolve
> your issues with 2.2.
> Regards,
> Christopher Schmidt
> MetaCarta
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20061116/e8f1febd/attachment.html
