[OpenLayers-Users] build.py...
Christopher Schmidt
crschmidt at metacarta.com
Mon Apr 2 16:32:10 EDT 2007
On Mon, Apr 02, 2007 at 03:17:27PM -0500, John Cole wrote:
> I've built the trunk and I have a question about deploying it to the
> webservers... What else do I need besides the js file? I assume theme and
> img, but putting those at the same level as the js file doesn't work.
> So what else and where do I need to put it? :-) Is there a faq that I
> missed on this?
The expected layout of a singlefile build is:
OpenLayers.js
img/
theme/
If this isn't working, something is broken. (Note that the naming of the
OpenLayers.js file matters.)
If your file isn't named OpenLayers.js, you should override your
OpenLayers._getScriptLocation():
OpenLayers._getScriptLocation = function(){return "/mydir/";}
mydir should be where the OpenLayers.js, img/ and theme/ directories
are.
Regards,
Christopher Schmidt
MetaCarta
