[OpenLayers-Users] geometry.getComponentsString()
Christopher Schmidt crschmidt at metacarta.com
Thu Apr 5 16:46:22 EDT 2007
On Thu, Apr 05, 2007 at 01:39:50PM -0700, Roger Kunkel wrote:
> geometry.getComponentsString()  doesn't work on a polygon?
> What's the easiest way to get a polygon's coordinates?
geometry.toString() should work on anything -- returns WKT. Is that good
enough?
Otherwise, you should iterate through geometry.components, and you can
call getComponenetsString on each component of the polygon (they are
linear rings).
Regards,
Christopher Schmidt
MetaCarta
