[OpenLayers-Users] Turning on/off layers depending on zoom level
kaka
drspencer at hotmail.com
Tue Apr 10 17:53:18 EDT 2007
This is an example of the problem I have:
http://www.villageografica.com/test44/Africa-test.html
If I change the maxResolution to 0.2 the map works fine, but its current 0.3
won´t work. I hope this illustrates my problem.
Magnus
Erik Uzureau-3 wrote:
> Dear Kaka,
> Do you have a live example that you could post a link to?
> Offhand, I can't see what the problem is... but I might be
> able to help you out if I could see it in action
> Erik,
> Best
> On 4/10/07, kaka <drspencer at hotmail.com> wrote:
>> Thank you very much, Erik, this has been a great help. However, I have
>> run
>> into a problem. If the markers are set to not show on first load, but to
>> appear when zooming in, the show/hide functionality stops working and the
>> markers are dislocated when zooming out. My code looks like this:
>> var MarkersLayer2 = new OpenLayers.Layer.Text( "Region info", {location:
>> "markers.txt", maxResolution: 0.03});
>> Changing the "0.3" to "0.2" causes the problems mentioned above. Is this
>> related to my code or a possible bug?
>> Magnus
>> kaka wrote:
>> > Hi
>> > I am trying to turn on/off a layer of markers depending on zoom level,
>> > using google maps as a background layer. Does anyone have suggestions
>> on
>> > how to achieve this or is there or maybe an example? Thank you for any
>> > ideas.
>> > Regards,
>> > Magnus
>> View this message in context:
>> http://www.nabble.com/Turning-on-off-layers-depending-on-zoom-level-tf3550126.html#a9927966
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
View this message in context: http://www.nabble.com/Turning-on-off-layers-depending-on-zoom-level-tf3550126.html#a9929477
