[OpenLayers-Users] Markers and Projections
Pierre GIRAUD
bluecarto at gmail.com
Fri Apr 13 10:56:31 EDT 2007
I played around with your sample and found out what was wrong.
I think you couldn't invent but this works if your call
map.zoomToMaxExtent() before you add markers to your layer.
Looking in the code, I could see that the addMarkers method need to
know the current map extent. For a map with a specific projection, the
map.getExtent() method won't return a value till a setCenter, or
zoomTo[..] or whatever is called.
Regards
Pierre
On 4/13/07, david delannoy <david.delannoy at avignon.inra.fr> wrote:
> david delannoy a écrit :
> > Hello,
> > I'm trying to display markers on a map wich display a layer in
> > projection 27582. It seems that it doesn't work while it works for the
> > projection 4269. Here is a part of my code.
> > Thank in advance for your help.
> > var llon = 658500;
> > var llat = 2380000;
> > var options = {
> > maxResolution: "auto",
> > /* maxExtent is the maximum bounds, in the units of
> > your map,
> > of the plane in which you want to display information */
> > maxExtent: new
> > OpenLayers.Bounds(50000,1586013,1160964,2771788),
> > /* maxExtent is the minimum bounds, in the units of
> > your map,
> > minExtent: new
> > /* Number of zoom levels */
> > numZoomLevels: 4,
> > /* Unit of geographical values on the map */
> > units : "meters"
> > var ol_wms = new OpenLayers.Layer.WMS( "OpenLayers WMS",
> > "http://www.geosignal.org/cgi-bin/wmsmap?SRS=EPSG:27582&",
> > {layers: 'RASTER1000k',transparent: "false", format:
> > "image/png"}, options);
> > map.addLayer(ol_wms);
> > /* Ajout de markers */
> > var markers = new OpenLayers.Layer.Markers( "Markers" );
> > map.addLayer(markers);
> > var size = new OpenLayers.Size(20,30);
> > var offset = new OpenLayers.Pixel(-(size.w/2), -size.h);
> > var icon = new
> > OpenLayers.Icon('http://boston.openguides.org/markers/RED.png',size,offset);
> > var marker = new OpenLayers.Marker(new
> > OpenLayers.LonLat(llon,llat),icon);
> > markers.addMarker(marker);
> > marker.events.register('mousedown', marker, function(evt) {
> > alert(this.icon.url); Event.stop(evt); });
> > map.addControl(new OpenLayers.Control.LayerSwitcher());
> > map.zoomToMaxExtent();
> Does anybody can help me!? I don't find any informations about that
> problem. Which projection do you use with markers? Did you have any
> problems with markers on any projection? I'm new in OpenLayers and maybe
> I made a big mistake.
> Please advice.
> Thank you in advance,
> Bye
> David
> David DELANNOY
> Ingénieur en Bioinformatique
> Unité Agroclim
> Site Agroparc
> INRA AVIGNON
> 04 32 72 24 13
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
