[OpenLayers-Users] How to add OverviewMap that is open?
Christopher Schmidt
crschmidt at metacarta.com
Thu Apr 19 23:28:41 EDT 2007
On Thu, Apr 19, 2007 at 11:10:36PM -0400, Stephen Woodbridge wrote:
> I would like to add the OverviewMap, but have it start in the open
> position? How do I do this?
> I tried:
> var ovm = new OpenLayers.Control.OverviewMap();
> ovm.maximizeControl();
> map.addControl(ovm);
> but it was not happy with this, probably because this is not an event. I
> looked through the code but it was not obvious whether there was an
> option for this.
I just did tested this -- it seems to work after the control is added to
the map, and layers are added to the map. (It doesn't actually populate
the overview map until after it has a base layer to clone.)
map.addLayer(wms);
Will that work for you?
Regards,
Christopher Schmidt
MetaCarta
