[OpenLayers-Users] Turning on/off layers depending on zoom level
Erik Uzureau
erik.uzureau at metacarta.com
Fri Apr 20 13:50:25 EDT 2007
Kaka,
It is hard for people to help you because we need a more detailed
description of the problem.
I personally do not understand what is going wrong here.
Erik
On 4/17/07, kaka <drspencer at hotmail.com> wrote:
> Any help on this issue would be greatly appreciated. Could it be that this
> is
> a bug? The example is over at
> http://www.villageografica.com/test44/Africa-test.html and my problem is
> that the maxResolution doesn´t work with the zoom ranges I want and, also,
> that the markers are not in the correct position.
> Magnus
> kaka wrote:
> > This is an example of the problem I have:
> > If I change the maxResolution to 0.2 the map works fine, but its current
> > 0.3 won´t work. I hope this illustrates my problem.
> > Magnus
> > Erik Uzureau-3 wrote:
> >> Dear Kaka,
> >> Do you have a live example that you could post a link to?
> >> Offhand, I can't see what the problem is... but I might be
> >> able to help you out if I could see it in action
> >> Erik,
> >> Best
> >> On 4/10/07, kaka <drspencer at hotmail.com> wrote:
> >>> Thank you very much, Erik, this has been a great help. However, I have
> >>> run
> >>> into a problem. If the markers are set to not show on first load, but
> to
> >>> appear when zooming in, the show/hide functionality stops working and
> >>> the
> >>> markers are dislocated when zooming out. My code looks like this:
> >>> var MarkersLayer2 = new OpenLayers.Layer.Text( "Region info",
> {location:
> >>> "markers.txt", maxResolution: 0.03});
> >>> Changing the "0.3" to "0.2" causes the problems mentioned above. Is
> this
> >>> related to my code or a possible bug?
> >>> Magnus
> >>> kaka wrote:
> >>> > Hi
> >>> > I am trying to turn on/off a layer of markers depending on zoom
> level,
> >>> > using google maps as a background layer. Does anyone have
> suggestions
> >>> on
> >>> > how to achieve this or is there or maybe an example? Thank you for
> any
> >>> > ideas.
> >>> > Regards,
> >>> > Magnus
> >>> View this message in context:
> http://www.nabble.com/Turning-on-off-layers-depending-on-zoom-level-tf3550126.html#a9927966
> >>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> >>> _______________________________________________
> >>> Users mailing list
> >>> Users at openlayers.org
> >>> http://openlayers.org/mailman/listinfo/users
> >> Users mailing list
> http://www.nabble.com/Turning-on-off-layers-depending-on-zoom-level-tf3550126.html#a10048769
> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070420/886eeb4f/attachment.html
