[OpenLayers-Users] print preview.
Murali Maddali
murali.maddali at uai.com
Fri Apr 20 20:41:36 EDT 2007
After further testing I found that this has to do with the width of the div
tag. And also if I increase the scale in the print preview, the map
disappears. How do I stop this behavior. By the way boxes.html works in
print preview, that is how I found out that this has to do with the size of
the map. I am trying to print my map and have my base layers visible in my
print preview.
Thank you,
Murali K. Maddali
256-705-5191
murali.maddali at uai.com <mailto:murali.maddali at uai.com>
_____
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On
Behalf Of Murali Maddali
Sent: Friday, April 20, 2007 7:08 PM
To: openlayers
Subject: [OpenLayers-Users] print preview.
Hello All,
I am trying to show the map up in print preview. I am trying the lite.html
in the examples directory. But can't get to show up in print preview. Can
any one point me what I am doing wrong.
Thank you all.
Regards,
Murali K. Maddali
UAI, Inc.
(256) 705-5191 (W)
"Always bear in mind that your own resolution to succeed is more important
than any one thing." - Abraham Lincoln
This email and any files transmitted with it are confidential and intended
solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the sender. This
message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not
disseminate, distribute or copy this e-mail.
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070420/ce727581/attachment.html
