[OpenLayers-Users] Stopping map events
Jeff Dege
jdege at korterra.com
Wed Aug 1 11:15:53 EDT 2007
> From: euzuro at gmail.com [mailto:euzuro at gmail.com] On Behalf Of
> Erik Uzureau
> Sent: Tuesday, July 31, 2007 5:48 PM
> To: Jeff Dege
> Cc: users at openlayers.org
> Subject: Re: [OpenLayers-Users] Stopping map events
> On 7/31/07, Jeff Dege <jdege at korterra.com> wrote:
> > I have a div that is being drawn on top of the map.
> > Clicks in this div are being interpreted as clicks on the map.
> > Is there a way of either keeping clicks in this div from reaching
the
> > map, or of temporarily stopping event handling by the map, while the
div
> > is in place?
> If you search for and study the OpenLayers.Event.Stop() function, you
should
> be able to do this no problem.
Digging into that functionality would seem to be necessary if I were
trying to stop events from my div from propogating to the map.
OpenLayers.Popup does this - registering itself on a number of events,
preventing the underlying map from seeing them when the event happened
in the popup.
What I'm looking for is quite a bit simpler, if somewhat more drastic.
I don't want the map to respond to input at all, until I let things go
again. A simple kludge is to add a boolean idle:false to
OpenLayers.Events, then to add 'if (this.idle) return;' to the beginning
of OpenLayers.Events.TriggerEvents().
Then, between if I set map.events.idle = true, when I display my div,
and set it to false when I bring it down, the map will respond to
nothing while my div is visible - making it act like a modal dialog.
