[OpenLayers-Users] Question on having multiple layers
Gregor Mosheh
gregor at hostgis.com
Wed Aug 8 15:47:26 EDT 2007
Ali Khan wrote:
> some what. This much I knew already but I was hoping to grab the layer
> visible as well so I knew which layer to query data for.
I suppose you'd want to iterate through the list of all layers and stop
at the first that's both visible and also queryable. Should be simple,
if "queryable" can be defined in calculable terms. (the object's class?
some custom attribute you stick in there? all of them?)
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
only if you can restore." - AMANDA
