[OpenLayers-Users] Compressed Open Layers
Christopher Schmidt
crschmidt at metacarta.com
Fri Aug 10 09:18:03 EDT 2007
On Thu, Aug 09, 2007 at 10:30:23AM +0100, Tom (JDi Solutions) wrote:
> Hi all,
> I'm currently experimenting with compressing OpenLayers and have been
> running build.py to create a compressed version of the library, however the
> smallest version I seem to be able to make is 220K and from the output at
> the command line it seems to be including loads more stuff than I actually
> need despite my library.cfg file looking like this:
> I'm assuming I may actually need Rico, SingleFile, OpenLayers and
> BaseTypes? But is it possible to get rid of the likes of virtualearth,
> yahoo and all that stuff? All I want in this version is WMS, some mouse
> controls and point and I want the file as small as possible. 220K just
> seems like more than it ought to be?
> Do I need to specifically include all the stuff I don't want in the exclude
> list or are things included as dependencies?
http://trac.openlayers.org/wiki/Profiles
"If you wish to create a build where you must specify each file you wish
to include, you should then add files to an '[include]' stanza, as
lite.cfg does. If you wish to create a build where all files in the lib/
directory are included by default, and you wish to *exclude* certain
files, you can do this by putting filenames under the [exclude] header.
Look at the files library.cfg and lite.cfg in the build/ directory for
examples of this behavior."
Dependancies are/should be added automatically, though there are many
files that are missing dependancies that you may have to add manually.
missing dependancies can be filed as bugs.
Regards,
Christopher Schmidt
MetaCarta
