[OpenLayers-Users] Compressed Open Layers
Tom (JDi Solutions) tom.dean at jdi-solutions.co.uk
Fri Aug 10 10:11:54 EDT 2007
It doesn't work!
All js errors are now gone and I have library.cfg as below, the map pans
around when I click and drag and I can move my markers but the pan zoom bar
and layer switcher controls are not visible.  They are in the DOM, I just
can't work out why I can't see them, with the full code they work fine.
Here's my current library.cfg
[first]
OpenLayers/SingleFile.js
OpenLayers.js
OpenLayers/BaseTypes.js
OpenLayers/Util.js
Rico/Corner.js
[last]
[include]
OpenLayers/Marker.js
OpenLayers/Layer/Markers.js
OpenLayers/Icon.js
OpenLayers/Control/MouseDefaults.js
OpenLayers/Control/LayerSwitcher.js
OpenLayers/Control/PanZoomBar.js
OpenLayers/Events.js
OpenLayers/Map.js
OpenLayers/Layer.js
OpenLayers/Layer/Grid.js
OpenLayers/Layer/HTTPRequest.js
OpenLayers/Layer/WMS.js
OpenLayers/Layer/WMS/Untiled.js
OpenLayers/Tile.js
OpenLayers/Tile/Image.js
[exclude]
On 8/10/07, Tom (JDi Solutions) <tom.dean at jdi-solutions.co.uk> wrote:
> Ah stunning, thanks very much, it's down to 89K so if I also get the
> webserver to compress it there'll hardly be anything left.  Now I just have
> to see if it works!
> thanks.
> On 8/10/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> > On Thu, Aug 09, 2007 at 10:30:23AM +0100, Tom (JDi Solutions) wrote:
> > > Hi all,
> > > I'm currently experimenting with compressing OpenLayers and have been
> > > running build.py to create a compressed version of the library,
> > however the
> > > smallest version I seem to be able to make is 220K and from the output
> > at
> > > the command line it seems to be including loads more stuff than I
> > actually
> > > need despite my library.cfg file looking like this:
> > > I'm assuming I may actually need Rico, SingleFile, OpenLayers and
> > > BaseTypes?  But is it possible to get rid of the likes of
> > virtualearth,
> > > yahoo and all that stuff?  All I want in this version is WMS, some
> > mouse
> > > controls and point and I want the file as small as possible.  220K
> > just
> > > seems like more than it ought to be?
> > > Do I need to specifically include all the stuff I don't want in the
> > exclude
> > > list or are things included as dependencies?
> > http://trac.openlayers.org/wiki/Profiles
> > "If you wish to create a build where you must specify each file you wish
> > to include, you should then add files to an '[include]' stanza, as
> > lite.cfg does. If you wish to create a build where all files in the lib/
> > directory are included by default, and you wish to *exclude* certain
> > files, you can do this by putting filenames under the [exclude] header.
> > Look at the files library.cfg and lite.cfg in the build/ directory for
> > examples of this behavior."
> > Dependancies are/should be added automatically, though there are many
> > files that are missing dependancies that you may have to add manually.
> > missing dependancies can be filed as bugs.
> > Regards,
> > Christopher Schmidt
> > MetaCarta
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070810/8422b554/attachment.html
