[OpenLayers-Users] how to synchronize 2 maps ?
Gilles Bassière
gilles.bassiere at makina-corpus.com
Mon Aug 13 10:14:38 EDT 2007
Stephen Woodbridge wrote:
> Gilles Bassière wrote:
>> Hi list,
>> I have 2 OL maps in the same page and I would like them to be
>> synchronized, say when an event occurred in any of the two maps, it
>> should be handled by the two maps, so that both maps always show the
>> same area. For example, I use map2's controls to zoom in and both
>> maps zoom in.
>> I've been told that it should be possible with OL but I can't find
>> any such thing in this list archives...
>> So far, my maps are initialized like this:
>> // Map options
>> var url1 = ... ;
>> var url2 = ... ;
>> var optionsSet = {
>> maxExtent: new OpenLayers.Bounds(590100, 2420300, 596600, 2428500),
>> maxResolution: 12,
>> numZoomLevels: 10,
>> units: "m",
>> tileSize: new OpenLayers.Size(256, 256),
>> projection: "EPSG:27572",
>> theme: "./compare/customOL.css",
>> controls: []
>> // Map definition
>> var map1 = new OpenLayers.Map($("map1"), optionsSet);
>> var map2 = new OpenLayers.Map($("map2"), optionsSet);
>> var background1 = new OpenLayers.Layer.WMS("Background", url1,
>> {layers: "Background", format: "image/png"}, {isBaseLayer: true,
>> reproject: false});
>> var background2 = new OpenLayers.Layer.WMS("Background", url2,
>> reproject: false});
>> map1.addLayer(background1);
>> map2.addLayer(background2);
>> map1.addControl( new OpenLayers.Control.MousePosition() );
>> map1.addControl( new OpenLayers.Control.MouseDefaults() );
>> map1.addControl( new OpenLayers.Control.PanZoomBar() );
>> map2.addControl( new OpenLayers.Control.MousePosition() );
>> map2.addControl( new OpenLayers.Control.MouseDefaults() );
>> map2.addControl( new OpenLayers.Control.PanZoomBar() );
>> I tried to assign the same control objects to both maps:
>> myPanZoomBarControl = new OpenLayers.Control.PanZoomBar() ;
>> map1.addControl( myPanZoomBarControl );
>> map2.addControl( myPanZoomBarControl );
>> The previous doesn't work. The control appear only on the 1st map and
>> control the 2nd map...
>> I also tried with the fallThrough property set to true but it doesn't
>> have much effect.
>> Has someone already got 2 maps synchronized ? Does someone know
>> whether it's possible ?
> I did something similar. To simplify things, I created a master and
> slave map so all the Controls are on the Master and then I added Event
> handlers to catch Move and Zoom events and to apply the action to the
> slave map. this worked very nicely.
> You might be able to criss/cross the event handlers but you would have
> to take some precautions to that update events did not trigger a new
> set up update events and so on form an endless loop.
> -Steve
Hi Steve
Thanks for your help. I thought it was possible to synchronize 2 maps in
an easy way, just turning on option on or something. Seems to be a
little more complicated and time-consuming. I just embolded myself and
dived into OL code, I think I can modify it to allow a control to drive
several maps but I have to find a little time. If I manage to write a
clean solution to this problem, I'll keep the list informed.
Cheers,
Gilles Bassiere
MAKINA CORPUS
30 rue des Jeuneurs
FR-75011 PARIS
http://www.makina-corpus.com
