[OpenLayers-Users] Ka-Map Layer Scale
Jerry O'Sullivan
jeremiahosullivan at gmail.com
Mon Aug 13 14:36:09 EDT 2007
Thanks Christopher,
That did the trick - once i added in my scale array to the map options
array-, however the map appears off center and chopped off, also the pan
functionality doesn't work. Here is a screen grab
http://img262.imageshack.us/my.php?image=nav2yy4.png. I debugged using
firebug and no tiles are created to the right. Tiles are outlined in pink
I think this has something to do with the projection- Have I have set the
projection on the map incorrectly? I have set the projection when
constructing the layer but that doesn't help
Thanks
On 13/08/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> On Mon, Aug 13, 2007 at 10:11:58AM -0700, GISGuru wrote:
> > <div style="width:100%; height:100%" id="map"></div>
> > <script defer="defer" type="text/javascript">
> > var options = {
> > Bounds: new OpenLayers.Bounds(0, 0, 450000, 450000),
> > projection: "EPSG:29903",
> > units: "meters"
> Change this to 'm' instead of 'meters'.
> Regards,
> Christopher Schmidt
> MetaCarta
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070813/41fcbb2b/attachment.html
