[OpenLayers-Users] Markers and Vector-Features displaced after
mouse-dragging
Zimmermann, Tobias
Tobias.Zimmermann at iml.fraunhofer.de
Wed Aug 22 10:49:10 EDT 2007
Hi Christopher!
Thanks alot for your reply!
I think I've managed to track down this problem to my own mapserver... I tested with the MetaCarta-Mapserver in Untiled-Mode and both, locations and markers stayed fixed on their positions, even after zooming and dragging like a maniac.
Think our MapServer needs some reconfiguration... Are their any examples for .map-Files available (perhaps the ones you have used for the live examples)?
Again, thanks alot and best regards,
Tobias
-----Ursprüngliche Nachricht-----
Von: Christopher Schmidt [mailto:crschmidt at metacarta.com]
Gesendet: Mittwoch, 22. August 2007 14:21
An: Zimmermann, Tobias
Cc: users at openlayers.org
Betreff: Re: [OpenLayers-Users] Markers and Vector-Features displaced after mouse-dragging
On Wed, Aug 22, 2007 at 10:35:43AM +0200, Zimmermann, Tobias wrote:
> Hi again!
> I'm trying to do some guesswork on this behaviour:
Vectors on top of Google are not supported in the 2.4 release. In a the next release, they will be supported via the GoogleMercator layer.
> - Since the markers stay correct with a Google-Maps-Base-Layer I
> assume that OpenLayers uses the GoogleMaps-API function to display them...
Nope.
> - This is documented somewhere and I haven't found it yet...
Doesn't look like it. We used to have an open ticket, but the GoogleMercator ticket subsumed it, and I never documented it well enough. I'm sorry about that.
> It would be really nice if someone could tell me about the reliability
> of Vector-Features. I'm trying to display routing-results which should
> match to the underlying map-routes. If OpenLayers is not able to
> display them correctly I would be in less trouble since I have an
> explanation ;)
Vector features are well supported outside of the commecial layers :) As I said, in the next release, this will be fixed, but at the moment, you're out of luck for vector support on top of commercial layers.
However, the untiled thing is new to me. Sharing an example with the list would help accelerate debugging on that one.
Regards,
Christopher Schmidt
MetaCarta
