[OpenLayers-Users] (no subject)
bradleyspencer
brad at cubewerx.com.au
Tue Aug 28 23:15:41 EDT 2007
When I use OpenLayers and use an external SLD file to render a layer, it
works just fine with one exception. It ignores any opacity setting for
individual rules which is supported in OGCs SLD spec. The only way I have
been able to set opacity is by setting it inside the list of options when
creating the layer. This simply overrides any SLD setting and is applied at
the layer level not rule level.
Is there anyway that I make sure Open Layers applies opacity as defined in
an SLD, which could be different for each of many rules for any given layer?
If not I will lodge a ticket.
Cheers,
Brad
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070829/613763d4/attachment.html
