[OpenLayers-Users] Switching to singleTile mode (and back) on
the fly
Christopher Schmidt
crschmidt at metacarta.com
Tue Dec 4 14:00:06 EST 2007
On Tue, Dec 04, 2007 at 06:17:08PM +0000, Jon Blower wrote:
> Hi Christopher,
> > Have two layers, and switch between them? You don't have to display them
> > both: when you switch, set the one you'r turning 'off' to
> > displayInLayerSwitcher false, then call cahngebaseLayer (or
> > setVisibility, if they are overlays) and change the layer.
> I've just tried this and don't quite get the result I expect. If I
> change the property displayInLayerSwitcher after a layer has been
> added to the map, nothing happens, even if I call
> layerSwitcher.redraw().
> Is there a way to add or remove a layer from the layer switcher after
> the layer has been added to the map?
I'm surprised this doesn't work. Can you craft a simple HTML example
demonstrating it that you can share?
Regards,
Christopher Schmidt
MetaCarta
