[OpenLayers-Users] Google and GML layer
Christopher Schmidt
crschmidt at metacarta.com
Thu Dec 6 10:39:49 EST 2007
On Thu, Dec 06, 2007 at 03:58:40PM +0100, Jacolin Yves wrote:
> Hi Christopher,
> I don't know if I understood what you mean but I tried in firebug console :
You did, thanks.
> >>> google.forwardMercator(4.812402,45.769954);
> lon=535714.1400579594,lat=5743560.513581038 lon=535714.1400579594 lat=5743560.513581038
> the GML layer shows no data there. 4.812402,45.769954 come from the GML file in WGS84 (first vertex from first polygon).
> The corresponding vertex in the new GML file in 'spherical Mercartor' is: 535714.140132531,5712913.07157348 which is incorrect (Y-offset).
> Does ogr need to supprot datum shifting for creating my file in spherical Mercator? (http://proj.maptools.org/faq.html#datumshifting)
I can give you a definite "I have no idea" :) I know that it's always
worked for me on Debian machines, but I have no idea what options that
is built with: I'd guess that 'yes' is a possible answer, but at the
very least, you've narrowed down your problem to OGR/Proj, and you can
probably get better help on the GDAL list: make sure to reference
http://proj.maptools.org/faq.html#sphere_as_wgs84 , since it will
probably help people help you better.
Regards,
Christopher Schmidt
MetaCarta
