[OpenLayers-Users] Control Panel Multiple Tools with different icons
Andrew de Klerk
andrew.deklerk at gmail.com
Thu Dec 6 15:45:49 EST 2007
Hi all
I will try and explain my problem as best as I can without confusing you. I
have searched the forum's but have not found a solution to my problem. I am
trying to implement a toolbar using the control Panel. My toolbar will
contain the following tools:
Zoom Extent
ZoomBox
Pan
Select feature
Delete Feature
Measure
Draw Point
Draw polygon
Draw Line
The measure tool will be implemented using the "DrawFeaturePath" and the
Delete feature using the "SelectFeature". I can successfully assign the
appropriate function to each tool, but cannot seem to get it right in
assigning an appropriate icon through the stylesheet - i.e Measure icon
always defaults to the DrawFeaturePathItemActive/Inactive icons regardless
of trying to assign it different classes.
What do I need to do to assign it a different icon? Also, How do you assign
the default control to your panel? I think my syntax must be incorrect below
for "defaultControl". Below is my code I have implemented:
___________________________________________________
var zb = new OpenLayers.Control.ZoomBox({title: "Zoom Box: Selecting it
you can zoom on an area by clicking and draging"});
var panel = new OpenLayers.Control.Panel({div:$('panel')},{defaultControl:
zb,'displayClass': 'olControlPanel'});
var select = new OpenLayers.Control.SelectFeature(vlayer,{onSelect:
onFeatureSelect, handlerOptions: {'displayClass': 'olControlSelectFeature'
var mt = new OpenLayers.Control.DrawFeature(vlayer,
OpenLayers.Handler.Path,
{featureAdded: ShowMeasureDistance,handlerOptions: {'freehand': false},
'displayClass': 'MeasureTool'});
// Add a multi-point polygon drawing tool tip container
var dply = new OpenLayers.Control.DrawFeature(vlayer,
OpenLayers.Handler.Polygon,
{featureAdded: handleFeatureAdded,handlerOptions: {'freehand': false},
'displayClass': 'olControlDrawFeaturePolygon'});
// Add a multi-point line drawing tool tip container
var df = new OpenLayers.Control.DrawFeature(vlayer,
'displayClass': 'olControlDrawFeaturePath'});
// Add a single point drawing tool tip container
var dp = new OpenLayers.Control.DrawFeature(vlayer,
OpenLayers.Handler.Point,
'displayClass': 'olControlDrawFeaturePoint'});
//add selecttodelete tool
var seldel = new OpenLayers.Control.SelectFeature(vlayer,{onSelect:
onFeatureSelectDelete, handlerOptions: {'displayClass': 'DeleteTool' }})
panel.addControls([ new OpenLayers.Control.ZoomToMaxExtent(),new
OpenLayers.Control.Navigation(), zb, select,mt,dply,df,dp,seldel ]);
//add panel to map
map.addControl(panel);
I hope that all makes sense
Regards
Andrew
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20071206/cdd43758/attachment.html
