[OpenLayers-Users] Control Panel Multiple Tools with different
icons
Andrew de Klerk
andrew.deklerk at gmail.com
Thu Dec 6 16:33:14 EST 2007
Thanks Christopher
I feel stupid for forgetting about it, but I needed the ItemActive and
ItemInactive class after the "measuretool"
i.e a css class for MeasureToolItemActive and another one for
MeasureToolItemInactive. So In my CSS it is like so:
.olControlPanel .MeasureToolItemInactive {
background-image: url("img/measure_off.png");
background-repeat: no-repeat;
.olControlPanel .MeasureToolItemActive {
background-image: url("img/measure_on.png");
Cheers
Andrew
-----Original Message-----
From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
Sent: 06 December 2007 10:59 PM
To: Andrew de Klerk
Cc: users at openlayers.org
Subject: Re: [OpenLayers-Users] Control Panel Multiple Tools with different
icons
On Thu, Dec 06, 2007 at 10:45:49PM +0200, Andrew de Klerk wrote:
> The measure tool will be implemented using the "DrawFeaturePath" and the
> Delete feature using the "SelectFeature". I can successfully assign the
> appropriate function to each tool, but cannot seem to get it right in
> assigning an appropriate icon through the stylesheet - i.e Measure icon
> always defaults to the DrawFeaturePathItemActive/Inactive icons regardless
> of trying to assign it different classes.
If you look in firebug, is your displayClass being applied? This would
show up as the class name being "MeasureTool" on the control.panel div.
> What do I need to do to assign it a different icon? Also, How do you
assign
> the default control to your panel? I think my syntax must be incorrect
below
> for "defaultControl". Below is my code I have implemented:
Control.Panel only takes on arg. Put 'em all together.
Regards,
Christopher Schmidt
MetaCarta
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.5.503 / Virus Database: 269.16.15/1173 - Release Date: 2007/12/05
09:29 PM
