[OpenLayers-Users] SVG Overlay
Pierre GIRAUD
bluecarto at gmail.com
Wed Dec 12 16:02:38 EST 2007
If you need vector symbols you should have a look at this example.
http://dev.openlayers.org/sandbox/camptocamp/vectorSymbols/examples/vector-symbols.html
Two notes :
- This only works for point features,
- this converts svg symbols into vml groups so that they can be
rendered into IE.
Regards,
Pierre
On Dec 12, 2007 9:28 PM, miles <miles.togoe at gmail.com> wrote:
> Tim Schaub wrote:
> > Hey-
> > miles wrote:
> >> Are there any examples of using a SVG overlay? I didn't see any. I
> >> suspect it's kind of tricky since I assume the SVG coordinate system
> >> would need to be translated to the coordinate system/projection being
> >> used for the base layer.
> > If you open the following page in Firefox, you're looking at an "SVG
> > overlay."
> > http://openlayers.org/dev/examples/rotate-features.html
> > Did you mean something different?
> yes, I realize OpenLayers renders in SVG or VML but I meant overlaying
> an actual SVG xml file. This would permit displaying icons made in
> Inkscape, etc and I would think be faster since OpenLayers does not have
> to convert the vector language code to SVG. Obviously it would only
> display in a browser that supports SVG - or should we say won't display
> in IE, the only browser that does not support SVG ):
> <?xml version="1.0" encoding="UTF-8" standalone="no"?>
> <!-- Created with Inkscape (http://www.inkscape.org/) -->
> <svg
> xmlns:svg="http://www.w3.org/2000/svg"
> xmlns="http://www.w3.org/2000/svg"
> version="1.0"
> width="744.09448"
> height="1052.3622"
> id="svg2">
> <defs
> id="defs4" />
> <g
> id="layer1">
> <path
> d="M 231.42858 336.64789 A 48.57143 47.142857 0 1 1
> 134.28572,336.64789 A 48.57143 47.142857 0 1 1 231.42858 336.64789 z"
> style="fill:#ff0000;fill-rule:evenodd;stroke:#000000;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1"
> id="path2160" />
> </g>
> </svg>
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
