[OpenLayers-Users] New control problem
Rosario Carbone
Rosario.Carbone at ipl.com
Mon Dec 17 11:37:09 EST 2007
Ciao Walter
For some reason I haven't discovered yet I can see some messages in my
mail box but not on the forum. I changed a little bit the example
select-feature-openpopup.html so I have duplicated the polygonLayer
(polygon and polygon1) so I can prove that you can actually toggle
between
two draw and select controls for the two layers as you like.
As far as I understood you need to write two controls ( so I did:
drawControls and drawControls1 ), one for each the two layers then you
want two onFeatureSelect events, right? Different for each layer and
than you need to write two handlers ( same for unselect ).
I think, but your code is not enough, so I suppose the problem you are
having is when you toggle between controls, in my examples I wrote two
functions:
toggleControl and toggleControl1 but you may need just one which is more
clever, be carefull when you deactivate controls, your routine you need
to deactivate all the controls and activate just one.
Have a look at the code, hope this help.
Ciao
Rosario
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
On Behalf Of Walter Lorenzetti
Sent: 17 December 2007 15:28
To: Maillist Openlayers users
Subject: [OpenLayers-Users] New control problem
Hi list,
I've a problem with OpenLayers.Control.SelectFeature
I've 3 gml in a array ( users[] ) and for every layers I add on map a
new control.SelectFeature for to show a popup
control[i] = new OpenLayers.Control.SelectFeature(users[i],{onSelect:
openPopup,selectStyle: style[i]});
map.addControl(control[i]);
control[i].activate();
but when every layers are visibile only for the last layer activated I
can obtain the popup on feature select but not for the other 2 layers
Do I some mistake?
thanks in advance
Walter
Please no .doc, .xls, .ppt, .dwg:
https://www.faunalia.it/dokuwiki/doku.php?id=public:OpenFormats
Walter Lorenzetti
email+jabber: lorenzetti at faunalia.it
www.faunalia.it
Cell: (+39) 347-6597931 Tel+Fax: (+39) 0587-213742 Piazza Garibaldi 5 -
56025 Pontedera (PI), Italy
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
The information transmitted is intended only for the person
or entity to which it is addressed and may contain
confidential and/or privileged material. If you are not the
addressee, any disclosure, reproduction, copying,
distribution, or other dissemination or use of this
communication is strictly prohibited. If you have received
this transmission in error please notify the sender
immediately and then delete this email.
Any representations or commitments expressed in this email
are subject to contract.
This message has been scanned for viruses and dangerous
content. However, it is essential that the recipient also
checks this message using commercially available mail
scanning and anti-virus software. IPL Information Processing
Limited accepts no liability for any loss or damage resulting
from any virus or other dangerous content in this message.
IPL Information Processing Limited is registered in England
and Wales under company registration number 1418818.
Registration took place at Cardiff on 10 May 1979. IPL
Information Processing Limited's registered office and
normal place of business is Eveleigh House, Grove Street,
Bath, BA1 5LR, United Kingdom. IPL is also registered for
Value Added Tax (VAT) under registration number GB 601 2931 83.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20071217/70f7a479/select-feature-openpopup.html
