[OpenLayers-Users] Different behavior of WFS layer in IE 7
andFirefox
bradleyspencer
brad at cubewerx.com.au
Tue Dec 18 17:12:16 EST 2007
Christopher,
Thanks for that. I do recall some discussion about this in the past now.
I will cascade and let CubeWerx do all the work.
Thanks.
Brad Spencer
-----Original Message-----
From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
Sent: Wednesday, 19 December 2007 8:40 AM
To: bradleyspencer
Cc: Yingqi Tang; users at openlayers.org
Subject: Re: [OpenLayers-Users] Different behavior of WFS layer in IE 7
andFirefox
On Wed, Dec 19, 2007 at 08:19:35AM +1100, bradleyspencer wrote:
> Christian,
(I'm Christopher. If you like, you can shorten that to Chris.)
> I have been able to overlay vectors from a WFS request over GoogleMaps
using
> default EPSG:4326 in IE7 quite OK. When doing this in FF it is overlayed
but
> is clearly not in the right position/orientation/scale therefore
projection
> problem).
> I have not used sphericalMercator as I need to overlay data from WMS
> services that do not support EPSG:900913.
> CubeWerx supports this projection but other remote services that I am
using
> do not so I am intending to cascade through CubeWerx WMS to handle this
> projection.
> But I do not understand why if it works in IE it does not also work in FF
> the same?
Because Firefox and IE use totally different rendering engines -- and to
make it work in FF, we have to accept a 40% performance decrease. Given
the option, we decided against supporting it, and instead pursued
spherical mercator, which also solved the problems of overlaying WMS
data. (Since overlaying WMS data on Google doesn't actually work without
spherical mercator either.)
Regards,
Christopher Schmidt
MetaCarta
