[OpenLayers-Users] Reverting to pan/zoom after feature insertion
Eric Lemoine
eric.c2c at gmail.com
Wed Dec 19 07:06:34 EST 2007
On Dec 19, 2007 12:37 PM, David E. Reksten <der at dod.no> wrote:
> On 19/12/2007, Eric Lemoine <eric.c2c at gmail.com> wrote:
> > On Dec 18, 2007 5:51 PM, David E. Reksten <der at dod.no> wrote:
> > > Hi,
> > > is there a way to revert back to the pan/zoom function once a feature
> > > has been finished (by double-clicking, normally)? I tried the
> > > following, where p.controls[0] is my pan/zoom button in the
> > > EditingToolbar:
> > > vectors.onFeatureInsert = function(feature) {
> > > p.activateControl(p.controls[0]);
> > > But this lets the double-click event pass through to the pan/zoom
> > > button, where it causes the error "this.point has no properties -
> > > /OpenLayers.js - Line 903". (Using rev. 4899)
> > What versio of OL do you use?
> Version 2.5
> OpenLayers.VERSION_NUMBER = "$Revision: 4899 $"
I commited a patch to trunk some days ago that may fix your problem.
> > > I'm sorry if this is more of a JavaScript question than OpenLayers,
> > > but I was unable to find a resolution with Google.
> > > Oh, and by the way, I can confirm Andrew de Klerk's recent post about
> > > an error in IE7 when doing a hard refresh of the page after inserting
> > > a feature.
> > Could you explain what a hard refresh is?
> Both F5 or Ctrl-F5 seems to trigger this error.
Does the problem exist on the OpenLayers examples (for example
<http://openlayers.org/dev/examples/modify-feature.html>)? I haven't
been able to reproduce here.
Eric
