[OpenLayers-Users] CVS format for OpenLayers.Layer.Text?
Alexandre Leroux
alexandre.leroux at ec.gc.ca
Thu Feb 1 12:16:27 EST 2007
Thanks Yves,
You're right with a serious caveat. I found how, however, the way to do
it in OpenOffice is awkward! You must (1) "save as" a CVS file
(confusing), (2) select the "Edit filter settings" which is off by
default. From my few tests, the serious caveat is you have to edit the
file manually anyway because OpenOffice forces you to add a text
delimiter of " or '. (tab is the field delimiter). And the "point"
column does not work if it's " 'point' " or " "point" " instead of "
point ".
Am I wrong? :-)
Cheers,
Alex
Yves Jacolin wrote:
> Hi Alaxandre,
> Le Mercredi 31 Janvier 2007 22:42, Alexandre Leroux a écrit :
>> while it can't generate the required
>> tab-delimited file.
> Yes it can ! You just need to tick the box of the options when exporting the
> cvs file in the windows openend to choose where to save the csv file !
> Regards
> Y.
Alexandre Leroux, M.Sc., Ing.
Environnement Canada / Environment Canada
Centre météorologique canadien / Canadian Meteorological Centre
Division de la réponse aux urgences environnementales /
Environmental Emergency Response Division
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070201/d1e1b898/attachment.html
