[OpenLayers-Users] Removing popups with clicks on map
Erik Uzureau
euzuro at gmail.com
Sun Feb 4 10:33:48 EST 2007
If you only want to be displaying one popup at a time, it probably
wouldn't kill grandma to just make a global variable... like
OpenLayers.map.MyPopup or something like that. Then you can kill
it from anywhere without worrying about passing the reference.
If you want to allow multiple popups at once, however, you will
need a more complex system.
On 2/4/07, Robert Buzink <post at robertbuzink.nl> wrote:
> hi Alex,
> You can find a way to pick up a clickevent in the map at
> http://openlayers.org/dev/examples/click.htm :
> map.events.register("click", map, function(e) {
> var lonlat = map.getLonLatFromViewPortPx(e.xy);
> alert("You clicked near " + lonlat.lat + " N, " +
> + lonlat.lon + " E");
> You can change the alert part to a destroy popup code. You should know
> though that the code you've written destroys a specific popup, named
> 'popup'. The add function in this example could also have been:
> daspop = new OpenLayers.Popup("chicken",
> new OpenLayers.LonLat(5,40),
> new OpenLayers.Size(200,200),
> "example popup",
> true);
> map.addPopup(daspop);
> In which case the destroy code would have been:
> markers.map.removePopup(daspop);
> daspop.
> destroy();
> daspop = null;
> In other words, in your code you will have to find out the name of the popup
> that is being shown, before you can destroy it. I have no idea how you
> should do that. Maybe someone else could answer that (or correct me when I'm
> wrong)?
> On 2/2/07, Alexandre Leroux <alexandre.leroux at ec.gc.ca> wrote:
> > Hi list,
> > I'm using OpenLayers.Layer.Text to plot some markers. I'd like popups to
> > disappear when a click on the map is done. Right now, the popup
> > disappear only if (1) another markers is selected and a new popup first
> > this second marker is shown, or if (2) the marker is clicked again. This
> > is not convenient to me.
> > I looked at the popups.html example provided. I simply added the destroy
> > popup code.
> > In my map div I added:
> > <div id="map" onclick="destroy()"></div>
> > and in my script section:
> > function destroy() {
> > popup.destroy();
> > But it does not work. Any idea why? It there another way to remove
> > popups on clicks? Should I open a ticket?
> > Thanks & have a great Friday!
> > Alex :-)
> > Alexandre Leroux, M.Sc., Ing.
> > Environnement Canada / Environment Canada
> > Centre météorologique canadien / Canadian Meteorological Centre
> > Division de la réponse aux urgences environnementales /
> > Environmental Emergency Response Division
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> Robert Buzink, website ontwerp en ontwikkeling
> Sint-Pietersaalststraat 123
> 9000 Gent
> +32 (0)9 33 00 267
> +32 (0)487 548 414
> robertbuzink.nl/webdesign
> Users mailing list
