[OpenLayers-Users] Mapping website visitors with OpenLayers?
Alexandre Leroux
alexandre.leroux at ec.gc.ca
Thu Feb 8 11:25:47 EST 2007
Hi list,
Thanks to David and Christopher. I was hoping to be able to do it with
OpenLayers alone :-)
I am not familiar with MapServer (or MapGuide or PostGIS, etc). I will
not have access to the server, so setting up a webmapping server seems
improbable. I'll try finding an easy solution.
Maybe one day OpenLayers will be able to do this (e.g. mapping huge
number of markers and mapping densities)? I hope so ;-)
Thank you and have fun,
Alex
Christopher Schmidt wrote:
> On Wed, Feb 07, 2007 at 08:49:24PM +0000, Alexandre Leroux wrote:
>> Would using a thousand markers from a textfile with
>> OpenLayers.Layer.Text be advisable?
> Definitely not. Even without the IE issues that come with displaying
> large numbers of markers, OpenLayers is only tested with up to 500
> markers in Firefox. Performance beyond that level is simply degraded too
> much.
>> Is there another mean with
>> OpenLayers that would be more appropriate that I haven't discovered?
>> Would there be a way to generate "density maps" (the density of visitors
>> in that case; colored pixels based on the number of dots below each
>> pixel) directly with OpenLayers?
> WMS. PostGIS can serve as a backend, MapServer can create the overlays,
> and you can make it an untiled image so that you don't have to split it
> up. I'm with David here: this is definitely the path you want to follow.
> Regards,
Alexandre Leroux, M.Sc., Ing.
Environnement Canada / Environment Canada
Centre météorologique canadien / Canadian Meteorological Centre
Division de la réponse aux urgences environnementales /
Environmental Emergency Response Division
