[OpenLayers-Users] DOCTYPE causes scripts to fail
Christopher Schmidt
crschmidt at metacarta.com
Fri Feb 9 14:45:16 EST 2007
On Fri, Feb 09, 2007 at 10:17:56AM -0800, Gary Townsend wrote:
> I have a page that with no doctype declared in the html the map displays
> just fun but when the designers apply their templates OpenLayers starts
> returning errors. I saw the XHTML patch through google but was unsure a)if
> that would affect my problem since this is affecting even HTML Doctypes b)
> how I would apply it if it did fix my problem.
1. Are you using the single file build, or the developement
automatic script-include builds?
2. Something more specific than 'starts returning errors' is neccesary
here. Starting from an example and showing the smallest number of
changes to cause an error is most beneficial, but if you can't do
that, an example HTML page, or even an error message that you get,
would be helpful in resolving problems.
Regards,
Christopher Schmidt
MetaCarta
