[OpenLayers-Users] no predefined zoomlevels
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Mon Feb 12 11:21:39 EST 2007
Okay, that makes sense.
Would I still be able to use the PanZoomBar control and assign a set of
scales to the PanZoomBar? So that it would represent street level,
neighbourhood level etc.? Or does it always take the scales from the map?
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Christopher Schmidt <crschmidt at metacarta.com>
Naar: Bart van den Eijnden OSGIS <bartvde at osgis.nl>
Cc: users at openlayers.org
Onderwerp: Re: [OpenLayers-Users] no predefined zoomlevels
Datum: 12/02/07 14:11
> On Mon, Feb 12, 2007 at 04:34:47PM +0100, Bart van den Eijnden (OSGIS)
wrote:
> &gt; Hi Christopher,
> &gt;
> &gt; I've seen this post. But isn't this to zoom to a specific scale?
> &gt;
> &gt; Or would I need to make my own set of controls and calculate the
scale based
> &gt; on the zoombox the user has drawn, and then use the workaround from
the
> &gt; post?
> Yeah. What I would do:
> I would make a subclass of the MouseWhatever control you are currently
> using. Once you've done that, you replace the zoomBoxEnd function:
> There's very litle you need to do other than copy the existing code and
> change:
>          var bounds = new OpenLayers.Bounds(left, bottom, right, top);
>          this.map.zoomToExtent(bounds);
> To instead calculate the resolution of the box and zoom to that scale,
> then set the center. (or the other way around.)
> Regards,
> Christopher Schmidt
> MetaCarta
