[OpenLayers-Users] secure WMS and WFS
Stephan Holl
stephan.holl at intevation.de
Thu Feb 15 02:18:37 EST 2007
Hello
users-request at openlayers.org, [20070214 - 17:57:16]
> Two things regarding that solution:
> (1) To me if the information isn't public one needs to encrypt that
> information. Authentication isn't sufficient.
> (2) For that solution to work the actual WMS server needs to support
> authentication. From what I've read so far, neither geoserver nor
> mapserver support it.
You could use deegree OWSProxy to secure your WMS/WFS-services. I used
this in some setups successfull. You will have a WAS to distribute
sessionsids which are checked against the OWSProxy.
This was done for sure over HTTPS though.
Check out the website[1]
HTH
Stephan
[1] http://deegree.org
Stephan Holl <stephan.holl at intevation.de>, http://intevation.de/~stephan
Tel: +49 (0)541-33 50 8 32 | Intevation GmbH | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
