[OpenLayers-Users] DOCTYPE causes scripts to fail
Gary Townsend
garyt at spatialmapping.com
Thu Feb 15 11:43:37 EST 2007
Well our designer managed to fix the problem. What was causing the problem I
guess was when I, great designer I am not, made up the working page without
the template applied I made a Loading Imagery gif to sit in the background.
I then used z-index to layer it behind the map div tag.
Our designer changed this last night. She set the standby gif to be a
background for the div tag for the map and voila. Presto changeo. The
OpenLayers scripts now run perfectly find under the doctypes.
-----Original Message-----
From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
Sent: February 11, 2007 10:23 AM
To: Gary Townsend
Cc: users at openlayers.org
Subject: Re: [OpenLayers-Users] DOCTYPE causes scripts to fail
I highly recommend that everyone read this article:
http://www.quirksmode.org/css/quirksmode.html
There is a link at the right to this page which shows what happens in
each browser depending on the doctype you choose:
http://hsivonen.iki.fi/doctype/
I have had a lot of success standardizing on the following doctype:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/
TR/html4/strict.dtd">
This makes all the major browsers work in standards (or almost
standards) mode. Any choice you make yields predictable behaviour
but with standards mode, you seem to get less differences between the
browsers, or at least less weird stuff going on.
Cheers
Paul
On 9-Feb-07, at 3:30 PM, Gary Townsend wrote:
> Yes you're right my apologies I hit send before thinking my request
> full
> through.
> The errors I get vary on the browser in fire fox I get:
> Error: this.position has no properties
> Source File: http://localhost/lib/OpenLayers/Tile.js
> Line: 103
> IE 6 I get
> Line: 66
> Error: this.tile is null or not an object
> If I hit no to debug I then get
> Line: 413
> Error: Number Expected
> I hadn't tried it in any other browsers.
> These are the Doctype declarations I have tried it with.
> DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
> "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"
> !DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Frameset//EN"
> "http://www.w3.org/TR/html4/frameset.dtd"
> !DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
> "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd"
> The Javascript:
> <script src="/lib/OpenLayers.js"></script>
> <scripttype="text/JavaScript">
> function init(){
> var map = new OpenLayers.Map('map',
> {'maxResolution':'auto'});
> var ol_wms = new OpenLayers.Layer.WMS.Untiled(
> "Globe","http://www.resmap.com/resmapserver/mapserv.exe?map=C:/
> Inetpub/Resma
> pRoot/ResmapSearch.map", {layers: 'Globe', format: 'jpeg'},{ratio:
> 1} );
> var pb_wms = new
> OpenLayers.Layer.WMS.Untiled("Borders","http://www.resmap.com/
> resmapserver/m
> apserv.exe?map=C:/Inetpub/resmaproot/ResmapSearch.map", {layers:
> 'PoliticalBoundaries',format: 'gif', transparent:'true'} );
> map.addLayers([ol_wms,pb_wms]);
> map.addControl(new OpenLayers.Control.LayerSwitcher());
> map.setCenter(new OpenLayers.LonLat(0, 0),0);
> map.events.register("zoomend",map,function(e){
> var mapBounds = new OpenLayers.Bounds();
> mapBounds = map.getExtent();
> document.forms[0].txtMinX.value = mapBounds.left;
> document.forms[0].txtMinY.value = mapBounds.bottom;
> document.forms[0].txtMaxX.value = mapBounds.right;
> document.forms[0].txtMaxY.value = mapBounds.top;
> map.events.register("moveend",map,function(e){
> </script>
> From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
> Sent: February 9, 2007 11:45 AM
> To: Gary Townsend
> On Fri, Feb 09, 2007 at 10:17:56AM -0800, Gary Townsend wrote:
>> I have a page that with no doctype declared in the html the map
>> displays
>> just fun but when the designers apply their templates OpenLayers
>> starts
>> returning errors. I saw the XHTML patch through google but was
>> unsure a)if
>> that would affect my problem since this is affecting even HTML
>> Doctypes b)
>> how I would apply it if it did fix my problem.
> 1. Are you using the single file build, or the developement
> automatic script-include builds?
> 2. Something more specific than 'starts returning errors' is neccesary
> here. Starting from an example and showing the smallest number of
> changes to cause an error is most beneficial, but if you can't do
> that, an example HTML page, or even an error message that you get,
> would be helpful in resolving problems.
> Regards,
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
