[OpenLayers-Users] Changing map file FILTER parameter via URL -
WFS layer with OVF connection
Pedrazzi Gelsomini
pedrazzi.gelsomini at gmail.com
Mon Feb 19 06:45:32 EST 2007
just another question about filter problems...
I thought that all was working but I was trying with the code below:
var edit_mine_wfs = new OpenLayers.Layer.WFS( "My wfs", "
http://localhost/cgi-bin/mapserv?map=/var/www/thesilence/webroot/mapserver/config/data_points.map&",
{typename: "editMinePoints",
'ilter:'<Filter><PropertyIsEqualTo><PropertyName>user_id</PropertyName><Literal>
2</Literal></PropertyIsEqualTo></Filter>'}, { featureClass:
OpenLayers.Feature.WFS}, { featureClass: OpenLayers.Feature.WFS});
In the "Literal" of my filter I put "2" just to test it.. but now I must
pass the variable "current_user".
I would like something like this:
<Filter>
<PropertyIsEqualTo>
<Literal>current_user</Literal>
</Filter>
but it doesnt work and I cant see anything.
Is it possible?
Do I have to change the keyword "Literal"?
Probably the problem is that I haven't the access to the value variable and
the filter check the literal as a string "current_user" and not as its
integer value.
Thank you very much for every help.
Have a good week.
2007/2/16, Bart van den Eijnden (OSGIS) <bartvde at osgis.nl>:
> Hi,
> yes after the mylayer initialization if you use mergeNewParams.
> Please note, if you already know the user at initialization, you can
> pass the parameter "filter" already in the constructor of your layer,
> just like you pass in typename right now.
> The filter encoding I gave was just an example, for the right name of
> the PropertyName check the DescribeFeatureType response of your
> Mapserver WFS, something like:
> http://localhost/cgi-bin/mapserv?map=/var/www/thesilence/webroot/mapserver/config/data_points.map&typename=points&service=WFS&version=1.0.0&request=DescribeFeatureType
> I would advise you to first get things running by putting a direct URL
> in the browser, and then code the stuff in OpenLayers javascript, so try
> something like:
> http://localhost/cgi-bin/mapserv?map=/var/www/thesilence/webroot/mapserver/config/data_points.map&typename=points&service=WFS&version=1.0.0&request=GetFeature&filter=
> <test
> your filter here>
> Hope this helps.
> Best regards,
> Bart
> Pedrazzi Gelsomini schreef:
> > Thank you very much for your help.
> > I should ask you more information beacause i can't understand what i
> > have to do.
> > > var filter =
> '<Filter><PropertyIsEqualTo><PropertyName>user_id</PropertyName><Literal>3</Literal><
> > > /PropertyIsEqualTo></Filter>';
> > > mylayer.mergeNewParams({"filter":filter});
> > Putting these instruction above i have the following error
> > "this.map has no properties"
> > ( Grid.js - line 171 - var viewSize = this.map.getSize();
> > Do i have to insert these instructions after mylayer initialization,
> > that is in the function init() that creates my map?
> > Is it correct put in the <PropertyName> the name of a field that I get
> > from the SELECT query of the OVF file?
> > Is it enough to add this code lines or I have to do something other in
> > order to make working the Filter Encoding?
> > Sorry for the trivial questions but i am quite new in this subject.
> > Thanks a lot for your time!
> > <mailto:bartvde at osgis.nl>>:
> > Hi,
> > you need to use the FILTER parameter from the OGC WFS spec to do
> > this, check
> > this for more info:
> > http://mapserver.gis.umn.edu/docs/howto/filterencoding/
> > <http://mapserver.gis.umn.edu/docs/howto/filterencoding/>
> > then you need to call mergeNewParams on your OpenLayers layer:
> > var filter =
> > '<Filter><PropertyIsEqualTo><PropertyName>USER</PropertyName>
> > <Literal>Peter</Literal></PropertyIsEqualTo></Filter>';
> > Best regards,
> > Bart
> > OSGIS, Open Source GIS
> > http://www.osgis.nl
> > --------- Oorspronkelijk bericht --------
> > Van: Pedrazzi Gelsomini <pedrazzi.gelsomini at gmail.com
> > <mailto:pedrazzi.gelsomini at gmail.com>>
> > Naar: users at openlayers.org <mailto:users at openlayers.org> <
> > users at openlayers.org <mailto:users at openlayers.org>>
> > Onderwerp: [OpenLayers-Users] Changing map file FILTER parameter
> > via URL -
> > Datum: 16/02/07 13:02
> > > Hi everyone,I m using openlayers for my application and I have a
> > WFS layer
> > filled by my mysql database using mapserver.My layer
> > inizialitazion is:
> > > var user_wfs = new OpenLayers.Layer.WFS( "User Points",
> "http://localhost/cgi-bin/mapserv?map=/var/www/thesilence/webroot/mapserver/config/data_points.map&
> {typename:
> > "points"}, { featureClass: OpenLayers.Feature.WFS});
> > > In my file.map i have the following layer:LAYER
> > CONNECTION "my_points.ovf"
> CONNECTIONTYPE
> > OGR DATA "points"
> > METADATA
> > "wms_srs"
> > "EPSG:4326"
> > "wms_title"
> > "points"
> > "wfs_srs"
> > "EPSG:4326"
> > "wfs_title"
> > "points"
> > "gml_featureid"
> > "fid"
> > "gml_include_items"
> > "all" END NAME
> > "points" SIZEUNITS
> > PIXELS
> > STATUS ON DUMP TRUE
> > PROJECTION
> > "init=epsg:4326" END
> > > TOLERANCE 20 TOLERANCEUNITS
> > PIXELS TYPE POINT UNITS
> > METERS FILTERITEM
> > "user_id" #FILTER ""where
> > my_points.ovf is:<OGRVRTDataSource>
> > > <OGRVRTLayer
> name="points">
> > <SrcDataSource>ODBC:myuser/mypsw at mydns
> </SrcDataSource>
> > <SrcSQL> SELECT
> > data_points.id AS
> > fid, latitude, longitude, des_walks.com_user_id AS user_id
> > > FROM data_points JOIN
> > des_walks WHERE des_walks.id =
> > data_points.des_walk_id
> > </SrcSQL>
> > <GeometryType>wkbPoint</GeometryType>
> > <LayerSRS>WGS84</LayerSRS>
> > > <GeometryField
> > encoding="PointFromColumns" x="longitude"
> y="latitude"/>
> > </OGRVRTLayer></OGRVRTDataSource>but I need to change
> > the value
> > of the FILTER parameter in the map file via URL.
> > > The connection with database works and allows me to put my
> > points on my
> > map.I would like to filter these data by "user_id" and
> > show only
> > the data linked to a specific user, but i have to pass this
> > parameter via
> > url because it is not always the same.
> > > Now i m passing just the typename in the openlayers function,
> > but i dont
> > know how to change the FILTER parameter in my map
> > file.
> > FILTERITEM "user_id"
> > > #FILTER ""Any suggestion?Thank you
> > very much!
> > > _______________________________________________
> > > Users mailing list
> > > Users at openlayers.org <mailto:Users at openlayers.org>
> > > http://openlayers.org/mailman/listinfo/users
> > Ilaria Gelsomini
> > Francesca Pedrazzi
> bartvde at osgis.nl
> http://www.osgis.nl
Ilaria Gelsomini
Francesca Pedrazzi
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070219/e4dee462/attachment.html
