[OpenLayers-Users] Changing map file FILTER parameter via URL -
WFS layer with OVF connection
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Mon Feb 19 06:58:51 EST 2007
you should be able to use a javascript variable and pass that into the
constructor, so:
var wfs_filter =
'<Filter><PropertyIsEqualTo><PropertyName>'+user_id+'</PropertyName><Literal>
2</Literal></PropertyIsEqualTo></Filter>';
and then:
var edit_mine_wfs = new OpenLayers.Layer.WFS( "My wfs", "
http://localhost/cgi-bin/mapserv?map=/var/www/thesilence/webroot/mapserver/config/data_points.map&",
{typename: "editMinePoints", 'filter':wfs_filter}, { featureClass:
OpenLayers.Feature.WFS}, { featureClass: OpenLayers.Feature.WFS});
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Pedrazzi Gelsomini <pedrazzi.gelsomini at gmail.com>
Naar: Bart van den Eijnden OSGIS <bartvde at osgis.nl>
Cc: users at openlayers.org
Onderwerp: Re: [OpenLayers-Users] Changing map file FILTER parameter via URL
- WFS layer with OVF connection
Datum: 19/02/07 09:45
> Hi,just another question about filter problems...I thought that all was
working but I was trying with the code below:var edit_mine_wfs = new
wfs",
'ilter:'<Filter><PropertyIsEqualTo><PropertyName>user_id</PropertyName><Literal>
> 2</Literal></PropertyIsEqualTo></Filter>'}, {
featureClass: OpenLayers.Feature.WFS}, { featureClass:
OpenLayers.Feature.WFS});In the "Literal" of my filter I put
"2" just to test it.. but now I must pass the variable
"current_user".
> I would like something like
this:<Filter><PropertyIsEqualTo><PropertyName>user_id</PropertyName><Literal>current_user</Literal>
> </PropertyIsEqualTo></Filter>but it doesnt work and I cant see
anything.Is it possible?Do I have to change the keyword
"Literal"?Probably the problem is that I haven't the access to
the value variable and the filter check the literal as a string
"current_user" and not as its integer value.
> Thank you very much for every help.Have a good week.2007/2/16, Bart van
den Eijnden (OSGIS) <bartvde at osgis.nl>:
> Hi,yes after the mylayer initialization if you use mergeNewParams.Please
note, if you already know the user at initialization, you canpass the
parameter "filter" already in the constructor of your layer,
> just like you pass in typename right now.The filter encoding I gave was
just an example, for the right name ofthe PropertyName check the
DescribeFeatureType response of yourMapserver WFS, something like:
http://localhost/cgi-bin/mapserv?map=/var/www/thesilence/webroot/mapserver/config/data_points.map&typename=points&service=WFS&version=1.0.0&request=DescribeFeatureType
> I would advise you to first get things running by putting a direct URLin
the browser, and then code the stuff in OpenLayers javascript, so
trysomething like:
http://localhost/cgi-bin/mapserv?map=/var/www/thesilence/webroot/mapserver/config/data_points.map&typename=points&service=WFS&version=1.0.0&request=GetFeature&filter=<testyour
filter here>
> Hope this helps.Best regards,BartPedrazzi Gelsomini schreef:> Thank you
very much for your help.> I should ask you more information beacause i
can't understand what i> have to do.
> >> > var filter =>
'<Filter><PropertyIsEqualTo><PropertyName>user_id</PropertyName><Literal>3</Literal><>>
> mylayer.mergeNewParams({"filter":filter});>>
Putting these instruction above i have the following error>>
"this.map has no properties"> ( Grid.js
> - line 171 - var viewSize = this.map.getSize();>> Do i have to
insert these instructions after mylayer initialization,> that is in
the function init() that creates my map?> Is it correct put in
the <PropertyName> the name of a field that I get
> > from the SELECT query of the OVF file?>> Is it
enough to add this code lines or I have to do something other in> order
to make working the Filter Encoding?> Sorry for the trivial questions but
i am quite new in this subject.
> >> Thanks a lot for your time!>>>> 2007/2/16, Bart van
den Eijnden (OSGIS) <bartvde at osgis.nl> <mailto:
> bartvde at osgis.nl>>:>>
Hi,>> you need to use the FILTER parameter
from the OGC WFS spec to do> this,
check> this for more
info:>>
http://mapserver.gis.umn.edu/docs/howto/filterencoding/>
<http://mapserver.gis.umn.edu/docs/howto/filterencoding/>>>
then you need to call mergeNewParams on your OpenLayers layer:
> >> var filter =>
'<Filter><PropertyIsEqualTo><PropertyName>USER</PropertyName>>
<Literal>Peter</Literal></PropertyIsEqualTo></Filter>';
Best regards,>
Bart>> --> Bart van
den Eijnden> OSGIS, Open Source
GIS>
> http://www.osgis.nl>>> ---------
Oorspronkelijk bericht --------> Van: Pedrazzi
<mailto:pedrazzi.gelsomini at gmail.com>>>
Naar: users at openlayers.org <mailto:
> users at openlayers.org> <>
<mailto:users at openlayers.org>>>
Onderwerp: [OpenLayers-Users] Changing map file FILTER parameter
> > via URL -> WFS
layer with OVF connection> Datum: 16/02/07
13:02>> > Hi everyone,I m using openlayers
for my application and I have a> WFS
layer> filled by my mysql database using
> mapserver.My layer> inizialitazion
is:> > var user_wfs = new
OpenLayers.Layer.WFS( &quot;User
Points&quot;,>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
&nbsp;&nbsp;&nbsp;>
&quot;http://localhost/cgi-bin/mapserv?map=/var/www/thesilence/webroot/mapserver/config/data_points.map&amp;>
> &quot;,> >
> > > &nbsp;&nbsp;&nbsp;
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;
{typename:> &quot;points&quot;}, {
featureClass: OpenLayers.Feature.WFS});> >
> > > In my file.map i have the following
layer:LAYER&nbsp;&nbsp;&nbsp;>
CONNECTION &quot;my_points.ovf&quot;&nbsp;&nbsp;&nbsp;
CONNECTIONTYPE> OGR&nbsp;&nbsp;&nbsp;
DATA &quot;points&quot;&nbsp;&nbsp;&nbsp;
> > METADATA>
&nbsp;&nbsp;&nbsp;
&nbsp;&nbsp;&nbsp;>
&quot;wms_srs&quot;&nbsp;&nbsp;&nbsp;>
&quot;EPSG:4326&quot;> >
&quot;wms_title&quot;&nbsp;&nbsp;&nbsp;>
&quot;points&quot;&nbsp;&nbsp;&nbsp;>
&nbsp;&nbsp;&nbsp;
&quot;wfs_srs&quot;&nbsp;&nbsp;&nbsp;
&quot;EPSG:4326&quot;&nbsp;&nbsp;&nbsp;
&nbsp;&nbsp;&nbsp;>
&quot;wfs_title&quot;&nbsp;&nbsp;&nbsp;>
> > &nbsp;&nbsp;&nbsp;
&quot;gml_featureid&quot;&nbsp;&nbsp;&nbsp;>
&quot;fid&quot;> >
&quot;gml_include_items&quot;&nbsp;>
&quot;all&quot;&nbsp;&nbsp;&nbsp;
END&nbsp;&nbsp;&nbsp; NAME>
&quot;points&quot;&nbsp;&nbsp;&nbsp; SIZEUNITS
PIXELS&nbsp;&nbsp;&nbsp;> STATUS
ON&nbsp;&nbsp;&nbsp; DUMP
TRUE&nbsp;&nbsp;&nbsp;>
PROJECTION&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;
&quot;init=epsg:4326&quot;&nbsp;&nbsp;&nbsp;
END> > &nbsp;&nbsp;&nbsp;
TOLERANCE 20&nbsp;&nbsp;&nbsp;
TOLERANCEUNITS>
PIXELS&nbsp;&nbsp;&nbsp; TYPE
POINT&nbsp;&nbsp;&nbsp; UNITS
> > METERS&nbsp;&nbsp;&nbsp;
&nbsp;&nbsp;&nbsp; FILTERITEM>
&quot;user_id&quot;&nbsp;&nbsp;&nbsp; #FILTER
&quot;&quot;where> my_points.ovf
is:&lt;OGRVRTDataSource&gt;
&lt;OGRVRTLayer>
name=&quot;points&quot;&gt;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
&lt;SrcDataSource&gt;ODBC:myuser/mypsw at mydns&lt;/SrcDataSource&gt;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;>
&lt;SrcSQL&gt;&nbsp;&nbsp;&nbsp;
&nbsp;&nbsp;&nbsp; SELECT
> > data_points.id AS>
fid, latitude, longitude, des_walks.com_user_id AS
user_id> > &nbsp;&nbsp;&nbsp;
&nbsp;&nbsp;&nbsp; FROM data_points
JOIN> des_walks&nbsp;&nbsp;&nbsp;
&nbsp;&nbsp;&nbsp; WHERE des_walks.id =
data_points.des_walk_id&nbsp;&nbsp;&nbsp;>
&lt;/SrcSQL&gt;&nbsp;&nbsp;&nbsp;>
&lt;GeometryType&gt;wkbPoint&lt;/GeometryType&gt;&nbsp;&nbsp;&nbsp;
&lt;LayerSRS&gt;WGS84&lt;/LayerSRS&gt;>
&lt;GeometryField>
encoding=&quot;PointFromColumns&quot;
x=&quot;longitude&quot;
y=&quot;latitude&quot;/&gt;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;>
&lt;/OGRVRTLayer&gt;&lt;/OGRVRTDataSource&gt;but I need to
change> the value
> > of the FILTER parameter in the map file via
URL.> >> > The
connection with database works and allows me to put
my> points on my>
map.I would like to filter these data by &quot;user_id&quot; and
> > show only> the
data linked to a specific user, but i have to pass
this> parameter via>
url because it is not always the same.>
>> > Now i m passing just the typename in
the openlayers function,
> > but i dont> know
how to change the FILTER parameter in my map>
file.&nbsp;&nbsp;&nbsp;> FILTERITEM
&quot;user_id&quot;> >
&nbsp;&nbsp;&nbsp; #FILTER &quot;&quot;Any
suggestion?Thank you
> > very much!>
_______________________________________________>
> Users mailing list> >
> Users at openlayers.org
<mailto:Users at openlayers.org>> >
http://openlayers.org/mailman/listinfo/users
Ilaria Gelsomini> Francesca Pedrazzi--Bart van den EijndenOSGIS, Open
Source GIS
> bartvde at osgis.nlhttp://www.osgis.nl-- Ilaria GelsominiFrancesca Pedrazzi
