[OpenLayers-Users] Right-click menu
Graham Davis
gdavis at refractions.net
Wed Feb 21 15:54:07 EST 2007
Well, I seem to have found the answer to my own question, so I thought
I'd email it to the list just in case anyone else needs to know how.
Basically there is an oncontextmenu event for DOM objects. You can
assign this to a function and put any code you like in there, and then
return false at the end to ensure the event stops and doesn't display
the browser's context menu. So I added this to my map object to disable
all browser context menus from appearing on the map like so:
map.div.oncontextmenu = function noContextMenu(e) {return false;};
Seems to work well in both IE and FF (haven't test Opera or on a Mac).
Graham Davis
Refractions Research Inc.
Graham Davis wrote:
>I'm trying to implement a right-click menu on my map, similar to what
>you see here: http://maps.ask.com/maps. I've been able to properly
>recongnize a right-click event in the MouseDefeaults.js file on mousedown.
>My problem is that the browser's own right-click menu also appears, and
>I need to disable or stop this. I've tried stopping the event from
>propagating in the mousedown function after my code (and in the mouseup
>function since that is when the browser menu seems to appear) however
>this doesn't stop the browser menu from appearing.
>Has anyone been able to implement a right-click menu on their map that
>properly disables the browser's right-click menu?
>Also, this might be of importance, but I'm using the vector branch of
>code. I've noticed that when not using a vector layer, the right-click
>menu on the map brings up the image menu as you have clicked on an image
>in the map. When there is a vector layer overtop, right-clicking brings
>up the standard browser menu where you can view source and whatnot, so
>the menus are different. However, I think any fix for this would work
>for both (and I have been testing everything I try both with and without
>a vector layer). So far nothing works.
